| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > Technical > [FAQ] WARNING - DOES YOUR FRONT SUSPENSION KNOCK? |
| shmoogle Site Moderator Joined: 07 Sep 2005 Location: Me fail English? That's unpossible. Posts: 18589
Stickied and FAQ'd for ease of reference |
| Kaine Joined: 27 May 2006 Location: Hills of Shropshire Posts: 6067
| Darren Joined: 17 May 2007 Location: Weybridge Posts: 11
Mine has this knock thru the ARC system also. Still in dealer, they have changed the steering column and have also shown me the LR bullitin regarding knocking thru the dynamic response and have said that it is normal. There is no fix as this is how it works apparently. The noise is the hydralic valves. The bullitin states at 20 mph rock the steering and a knock will be heard left to right. |
| rrsjo Joined: 28 Nov 2006 Location: North Cambs Posts: 487
The following is a quoted from an earlier post by Nutty Nige and contains a test to positively identify whether the Dynamic Response 'KNOCKING FAULT' is present in your RRSport or whether a different fault is the cause of the knocking.
| rodsport Joined: 15 Jul 2007 Location: East Asia Posts: 7
I have a 2006 MY SC registered a month ago - I noticed this problem at low speed and was v concerned (as the same system had problems sending a water pipe type tapping through the brake pedal on delivery, which necessitated a software update).
if it were a charateristic of the car then mine should have the knock too - but it doesn't - said this before but it sounds like an assembly or components tolerance issue to me |
| Josh Joined: 24 Dec 2005 Location: Here, there and everywhere Posts: 1390
Kaine,
Guys - this thread should be joined by the admin police to the other (larger) one on the same topic - despite all this/these emails/qns there is no answer/realistic response from the manufacturer...................
| The doc Joined: 31 Oct 2006 Location: In a pond HYPNOTOAD Posts: 1082
Burn them ALL and in doing so liberate yourselfs from the knock...
| Peter Joined: 28 Feb 2006 Location: Maidenhead Posts: 156
Must be time for direct action!
| TB Joined: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 4550
If your DR has been disconnected or the fuse has blown you will get a warning light on the drivers binnacle.
I do drive my RRS hard on occasions.
| Sun Joined: 29 Aug 2007 Location: London Posts: 8
I am new to the forum, and have recently placed my order for RRS TDV8 HSE which I have been promised will arrive by end of September !
