Home > In Car Electronics > Using stock amp with aftermarket head unit
Page 2 of 5 <12345>
mgrover
I did indeed. Am going to spend today when I get home from work identifying the amp on cable. It must be part of that set of cables going to the ISO.
Then am tempted to nuke anything out of the fibre optic network that isn't used, ie the navigation module under the drivers chair, the upper screen, the old head unit.
Quote:
The head unit is definitely powered up as I've stripped the main circuit board out of the head unit and that's all connected, including the MOST cable...
I think you need to remove the slim head unit from the fibre optic network. Because it tries to take precedence over the MOST decoder. I just left it unplugged and could check power was getting to it because the fibre optic light was on. You can't have both the MOST decoder AND the old HU plugged in. They clash.
Quote:
Did you get the CANBUS adapter and SWC 'box' as well? As my SWC work and are programmable from the Android Head unit...
Aiye I did, but when I have it all hooked up with the screen retention the stock HU seems to capture the events rather than allowing my aftermarket headunit to sort it.
The only thing left for me after I get the REMOTE ON working is to do something with the upper screen, since it'll be dead, I wonder if I can run it strictly as either some crazy 360 camera setup that I've seen or just a reversing camera, but all without the stock HU
This seems to know the REMOTE ON for the FF RR http://2ndrodeo.com/2007-range-rover-ampsub-install
Am super tempted to throw all this crap out, get rid of the stock amp and stick in a small aftermarket one. But I've already sank like what 200-300quid into this now.
Post #595714 Fri Feb 28 2020 10:25am
sounds like The ant/amp blue cable output, from the aftermarket head unit needs connecting to a LR wire.
The LR wire powers up lots of things.
Post #595735 Fri Feb 28 2020 1:51pm
mgrover
I'll give that a shot and see where it goes.
Post #595736 Fri Feb 28 2020 3:23pm
humm
the landrover Red wire with blue stripe at the headunit needs grounding to power up the rest of the system
Try that and see if it helps. you can't leave it like that as you will get a flat battery
Post #595747 Fri Feb 28 2020 6:17pm
mgrover
So there's 3 power cables that go to headunit.
Red, black and green.
The first two are obvious, the green routes to the head unit ant power and there's an amp output from the head unit as well. Connecting the two yields nothing Sad
Post #595759 Fri Feb 28 2020 9:39pm
Andy K wrote:
humm
Post #595761 Fri Feb 28 2020 10:04pm
mgrover
What do you mean by grounding up? Ie just connecting to ground?
Post #595762 Fri Feb 28 2020 10:29pm
Yes as a test.
Ensure it’s not connected to your headunit
Post #595771 Sat Feb 29 2020 9:32am
mgrover
That worked, how do I hook that up to switch? Because otherwise batteries gonna drain :p
Although the amp does turn off with the switch?
Post #595783 Sat Feb 29 2020 12:41pm
You need a relay.
Pin 30 and 85 to ground
Pin 86 to headunit ant amp blue? Wire
Pin 87 to landrover wire red/blue
Post #595790 Sat Feb 29 2020 2:16pm
mgrover
Hmm the screen retention kit came with one and since I butchered the Censored out of it may as well reuse the relay. There's 100quud down the toilet to confirm a wire haha
Post #595797 Sat Feb 29 2020 2:40pm
mgrover
Are those pins on the original head unit plug? Also couldn't I hook it up to the ground provided by the aftermarket headunit? Wouldn't that be dead when head unit is off?
After looking up a diagram for a relay it all makes sense
Post #595799 Sat Feb 29 2020 2:51pm
Be nice to have a picture or description of what u have working.
Post #595837 Sun Mar 01 2020 9:00am
Guyzer73
Oman 2006 Range Rover Sport Supercharged Vesuvius Orange
How's it going with the diagnosis? I've been looking online and from what I can see the OEM head unit MUST remain in the circuit as it is the system generator for the MOST circuit.
As such it has been suggested that the MOST adapter must be placed after the head unit in the MOST circuit closer to the Logic 7 amp so that it intercepts the signal and pushes it's own audio to the amp.
I haven't found a diagram for the Sport, however, I found THIS which helps with troubleshooting. It also provided the diagram below:
Further, it provides a couple of MOST circuit loops, including this one:
HEAD UNIT CCC/CIC/NBT>>L7AMP>>SAT>>TCU>>MULF>>HEAD UNIT
which I think probably closest represents the Sports when considering the placement of the physical units connected to the MOST. As such to get the MOST adapter to work it would need to be between the Head Unit and L7 amp.
I'm going to give this a try and see if I get any audio working. I've also order a replacement OEM head unit as I think mine is not 100% working (red laser light is) just to see if that would make a difference, as it may not be triggering the amp.
Let me know your thoughts on the above.
Guy 2006 RRS S/C CONSTANTLY under modification...
1994 RRC 4.2l not LSE sadly gone but not forgotten
LR Defender 300Tdi - affectionately know as "The Black Beast"
Post #595898 Mon Mar 02 2020 6:19am
mgrover
I'd just connect the wire Andy said to ground and see if it yields the results you want. But I'd be interested if your technique would yield both head unit and upper head unit working with the ordering.
My issue is the relay is being weird and not working
Post #595902 Mon Mar 02 2020 9:44am
Page 2 of 5 <12345>
