Home > In Car Electronics > Using stock amp with aftermarket head unit
Page 5 of 5 <12345
Can u take another clear picture of the LR connector.
Post #602947 Sat Aug 08 2020 9:05am
Guyzer73
It's the same wire as per MrRovers post here:
https://imgur.com/a/plc9jTT
My concern is the 0v coming out of the relay, when I assume it should be 12v.
Cheers 2006 RRS S/C CONSTANTLY under modification...
Post #602948 Sat Aug 08 2020 9:05am
It’s meant to be ground. 0v
Maybe poor connection on 87
Post #602950 Sat Aug 08 2020 9:12am
Guyzer73
Here you go
Post #602951 Sat Aug 08 2020 9:17am
You should also hear a click from behind the glovebox at the same time as the other click
Post #602952 Sat Aug 08 2020 9:30am
Guyzer73
I was getting that.
I'm going to try new relay and spade connectors and go from there.
Also check L7 amp and it's getting 12v over the power supply so that's okay.
Is there a way to short circuit the amp to power it on? Really just to check Amos working as I haven't used it in years...
Cheers for all the help 2006 RRS S/C CONSTANTLY under modification...
Post #602953 Sat Aug 08 2020 9:34am
well if fuse 57 and 58 (behind glovebox) have power on them (when relay clicks), this mod is working
Post #602955 Sat Aug 08 2020 9:53am
If the amp isn't working the things to consider are:
1. Do you have a complete optical circuit loop.
2. Is a LR display unit plugged in above the radio and working
3. Is the bluetooth unit plugged in and working
Post #602956 Sat Aug 08 2020 10:01am
Guyzer73
Ok, following your numbering:
1. Yes all FO points are either connected and powered, or disconnected and looped.
2. Display is disconnected and FO looped.
3. BT disconnected and FO looped.
I'll double check I haven't missed a FO connector.
Post #602957 Sat Aug 08 2020 10:04am
Guyzer73
So.... It works πŸ‘πŸΌ
I'm guessing it was the relay in some way. Used a new one and connected everything back up, including AC controls, hazard switch, and transmission connectors.... Turned the ignition and it fired right up.
10x betters than the crappy in built system.
Sincere thanks for your help and patience πŸ‘πŸΌπŸ‘πŸΌ
Post #602961 Sat Aug 08 2020 10:39am
Guyzer73
Spoke too soon. Fire it up again and nothing...
Wtf....
Scratching head now .. 2006 RRS S/C CONSTANTLY under modification...
Post #602963 Sat Aug 08 2020 10:51am
Guyzer73
Ok, my bad looks like I have a wonky connection to the FO control box 🀦🀦
School boy error.
EDIT: On further research the wonky connection actually stems from the connector to the box of tricks. I've tried to stabilise it and it seems to work now. However, I'll have thelook into a more permanent solution when I try to tidy up the cabling next weekend.
Thanks again for the support, patience and help Guys Thumbs Up Thumbs Up
Post #602966 Sat Aug 08 2020 11:25am
mgrover
a bit more info on my part, sometimes 1/10 times the amp doesnt turn on. i turn the car off, turn it back on and hey presto works fine. no idea why.
also i currently have an issue of the audio cutting out when i go round corners fast enough Razz am guessing i need to ditch the crappy connectors and use solder/heat shrink.
Post #603098 Mon Aug 10 2020 3:25pm
Page 5 of 5 <12345
