Home > In Car Electronics > Using stock amp with aftermarket head unit
Page 4 of 5 <12345>
Guyzer73
Nice One Thumbs Up
Do you mind sharing a wiring diagram and what exactly you have done. I hope to emulate it and lose some of the cables behind the dash so I can tidy it up a bit. |Obviously losing the screen retention loom and excess from the amp bypass loom would be a good start.
Have you lost any of the functionality from the instrument binnacle? Specifically, can you get the voice button on the steering wheel to work with your new head unit. Also, can you access the "Settings" menu for things like lazy entry, dip mirrors etc? If these don't work I think you can strip the OEM head unit out completely.
Post #596033 Thu Mar 05 2020 6:03am
mgrover
I have indeed lost access to the settings menu since to need to use the <<and>> to operate it but now thats going to the head unit.
this is a WIP picture so excuse the mess:
https://imgur.com/a/plc9jTT
I hope that makes sense
ill test the voice button but the answer and hang up buttons work fine
I have completely removed the OEM head unit, am not using the screen retention loom but the simpler one that provides power and swc. Much cleaner wires wise then.
Post #596045 Thu Mar 05 2020 10:35am
maybe if you connected the relay pin 86 to the headunit trigger wire, the system may start up without popping. Worth trying.
the optical convertor ign wire may need connecting to the headunit output too
Post #596049 Thu Mar 05 2020 1:07pm
mgrover
Am not gonna lie I am pretty happy it's finally working I don't wanna touch it. The popping I can live with imo.
This way the relay is completely isolated from the head unit. so I can take the headunit out as much as I want without worrying about the relay disconnecting.
thanks for your help again, i would of been pretty lost otherwise.
edit: For guy, I lost the use of the speech button on the left of the steering wheel. Can ya do.
Post #596073 Thu Mar 05 2020 6:04pm
Guyzer73
Cheers Mate Thumbs Up
Great to hear you've got things working. I suspect the voice won't work as the settings don't either.
I'm being a bit dim on the elctrics can you help confirm my wiring diagram below and point me in the right direction as to which wire exactly I need to connect to to trigger the L7 amp on?
Hopefully get this sorted this weekend and then it's the home run on tidying the old girl up..
Post #596242 Mon Mar 09 2020 7:48am
mgrover
That wiring diagram looks correct to me Smile AndyK can you confirm?
Although my 30 and 85 both went to ground.
Post #596248 Mon Mar 09 2020 11:51am
Guyzer73
Cheers mgrover,
Could you tell me exactly which wire you connected to trigger the L7 amp? Would help if you gave location and wiring colouring.
Appreciate the help. Thumbs Up
Cheers 2006 RRS S/C CONSTANTLY under modification...
Post #596249 Mon Mar 09 2020 12:33pm
mgrover
in this image https://imgur.com/a/plc9jTT
It has the blue splicer and connector
Post #596250 Mon Mar 09 2020 12:46pm
Andy K wrote:
You need a relay.
Pin 30 and 85 to ground
Pin 87 to landrover wire red/blue
Post #596252 Mon Mar 09 2020 1:07pm
Guyzer73
Thanks Andy K & mgrover,
Will give this a crack in the next couple of days Thumbs Up
Post #596286 Tue Mar 10 2020 6:28am
Guyzer73
Guys,
Having a blonde moment. If I have a decent Amp On wire from my head unit, could I just connect it to the appropriate wire (red/blue) and it should work?
Or as stated am I being blonde?
Post #596409 Thu Mar 12 2020 2:52pm
mgrover
you still need to complete the circuit with the ground. my head unit had a amp on cable but just connecting to that isn't enough since that is basically just v12 switched on.
Post #596411 Thu Mar 12 2020 3:15pm
Guyzer73 wrote:
Guys,
No this doesn't work, which is why the relay is needed
Post #596423 Thu Mar 12 2020 7:20pm
Guyzer73
Hi Guys
So finally got around to doing this... And it doesn't work. I think it's the relay,but let me explain.
I've connected 30 & 85 to ground. 86 to 12vdc switched and 87 to the green blue/ red cable.
However, using a multimeter I'm getting 12v across 86 and or 30/ 85 but 0vdc on 87. Is this correct or is the relay fried? I'm hearing a click when power is applied but that's it.
I'll try find another relay,but your input would be appreciated 👍🏼
Post #602945 Sat Aug 08 2020 8:55am
I think you connect 87 to the wrong wire.
Re read carefully and be sure.
Post #602946 Sat Aug 08 2020 8:58am
Page 4 of 5 <12345>
