Home > In Car Electronics > Using stock amp with aftermarket head unit |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 |
I did indeed. Am going to spend today when I get home from work identifying the amp on cable. It must be part of that set of cables going to the ISO.
I think you need to remove the slim head unit from the fibre optic network. Because it tries to take precedence over the MOST decoder. I just left it unplugged and could check power was getting to it because the fibre optic light was on. You can't have both the MOST decoder AND the old HU plugged in. They clash.
Aiye I did, but when I have it all hooked up with the screen retention the stock HU seems to capture the events rather than allowing my aftermarket headunit to sort it. The only thing left for me after I get the REMOTE ON working is to do something with the upper screen, since it'll be dead, I wonder if I can run it strictly as either some crazy 360 camera setup that I've seen or just a reversing camera, but all without the stock HU This seems to know the REMOTE ON for the FF RR http://2ndrodeo.com/2007-range-rover-ampsub-install Am super tempted to throw all this crap out, get rid of the stock amp and stick in a small aftermarket one. But I've already sank like what 200-300quid into this now. |
Fri Feb 28 2020 10:25am |
I'll give that a shot and see where it goes. |
Fri Feb 28 2020 3:23pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4798 |
humm
Fri Feb 28 2020 6:17pm |
So there's 3 power cables that go to headunit.
Fri Feb 28 2020 9:39pm |
Fri Feb 28 2020 10:04pm |
What do you mean by grounding up? Ie just connecting to ground? |
Fri Feb 28 2020 10:29pm |
Yes as a test.
Sat Feb 29 2020 9:32am |
That worked, how do I hook that up to switch? Because otherwise batteries gonna drain :p
Sat Feb 29 2020 12:41pm |
You need a relay.
Sat Feb 29 2020 2:16pm |
Hmm the screen retention kit came with one and since I butchered the out of it may as well reuse the relay. There's 100quud down the toilet to confirm a wire haha |
Sat Feb 29 2020 2:40pm |
Are those pins on the original head unit plug? Also couldn't I hook it up to the ground provided by the aftermarket headunit? Wouldn't that be dead when head unit is off?
Sat Feb 29 2020 2:51pm |
Be nice to have a picture or description of what u have working. |
Sun Mar 01 2020 9:00am |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 |
How's it going with the diagnosis? I've been looking online and from what I can see the OEM head unit MUST remain in the circuit as it is the system generator for the MOST circuit.
Mon Mar 02 2020 6:19am |
I'd just connect the wire Andy said to ground and see if it yields the results you want. But I'd be interested if your technique would yield both head unit and upper head unit working with the ordering.
Mon Mar 02 2020 9:44am |
