![]() | Home > In Car Electronics > Using stock amp with aftermarket head unit |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 ![]() ![]() ![]() |
Anyone seen or used this before?
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 ![]() ![]() ![]() |
Looks good although only has one set of RCA inputs so not sure how you could get front to rear fading and sub level control TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071 ![]() ![]() |
Use two of these?? - one for the front and one for the back speakers. But then good amps are not all that expensive so just replace the OEM amp under the seat with one that will power the speakers with input from the new head unit. Garry 07MY RRS TDV6 Arctic Frost Aspen Interior |
Don't think two are an option as the amp only has one MOST input
am not the audiophile you guys seem to think i am |
Fair enough. Would be good to post a review on it once you have fitted it TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten |
ill probably try make a video series out of it. its been hard to find resources for the L320 in terms of head units.
shameless bump, its all hooked up with a screen retention kit to boot.
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
Hmmm,
thats the results page https://www.rrsport.co.uk/forum/topic55744.html
Hi,
I think in your case you connect that remote on from your head unit to the MOST interface. Since it'll power on the amp via fibre optic. I think my setup just bypasses the headunit and goes directly to the lighter, bit more caveman but yah. |
I've figured out the problem your having, the network breaks when the head unit is unplugged because the upper screen isn't powered on. Mine worked because I have the screen retention kit which keeps the head unit powering on. But steering wheel controls don't work in my setup because the stock head unit captures them
Thanks Mate for all the help. |
