Home > Technical > Fuel burning heater not starting
Page 4 of 10 <12345678910>
kav1187
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
I'm in Essex. No idea if it will fire up when I start the car though...will let you know tomorrow Thumbs Up Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section Thumbs Up
http://rrsport.co.uk/forum/topic28424.html
Post #370705 Wed Jan 23 2013 7:08pm
madmackie
United Kingdom 2005 Range Rover Sport TDV6 HSE Bonatti Grey
pm sent
Post #370707 Wed Jan 23 2013 7:11pm
sherlock
2008 Range Rover Sport TDV8 HSE Santorini Black
I have always wondered if mine worked as I never ever see smoke from the small exhaust. So the other day after the car had started I opened the bonnet and felt the consatina style pipe - what a nob!! Damn hot and burnt my hand. I assume it works then hey? Banging Head Banging Head Censored TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
20" HST alloys, Privacy glass, Side steps, Xenon Adaptive Lighting, Adaptive cruise control
Post #370708 Wed Jan 23 2013 7:11pm
kav1187
At least you're sure it works Laughing
I've added a link on my previous post to ebay where someone is selling the OBD cables as I forgot to mention it.
I really hope it'll start up from cold! Bow down Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section Thumbs Up
Post #370711 Wed Jan 23 2013 7:37pm
RobP
Wow Kav, excellent and informative post and you have just saved me from posting the full "how to" post I intended to do. Bow down
My leads only turned up today so not had chance to do anything yet but the only difference will be that I will add how to adapt one of THESE £1.99 OBDII adapter leads
to avoid having to do this bit
Not critical but just makes a slightly neater solution Thumbs Up TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten
Post #370729 Wed Jan 23 2013 9:46pm
RobP
There should be no reason why it doesn'tThumbs Up TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten
Post #370732 Wed Jan 23 2013 9:50pm
madmackie
cant wait to see it rob
Post #370733 Wed Jan 23 2013 9:50pm
kav1187
Rob - the neatest solution is to just run a wire from port 2 on the FBH connector to port 7 on the diagnostic socket under the steering wheel. That way you don't have to mess about with the battery or even have to open your bonnet.
I'll be doing this when I next get a chance.
Your connector should work providing that 3 of the 4 pins go to the ports we use for the FBH Thumbs Up
Crocodile clips for the battery terminal connections might be best. I just wedged mine in Laughing Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section Thumbs Up
Post #370743 Wed Jan 23 2013 10:11pm
RobP
Yes Kav you are right the ultimate solution is to populate the OBDII port in the car as you suggest with the K bus pin 7.
A the moment I cant be Censored to run the lead back into the cabin but if it becomes a regular need I can think again Thumbs Up
the black plug contains +ve and -ve which i will replace with the croc clips i ordered at the same time for 99p Mr. Green and the white plug has K bus (pin 7 in OBDII plug) and L bus (pin 15 in OBDII plug) i will simply ignore the L bus cable and just use the K bus one.
All three wires that are needed Thumbs Up TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten
Post #370745 Wed Jan 23 2013 10:25pm
kav1187
Perfect! That'll do the trick nicely Thumbs Up Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section Thumbs Up
Post #370747 Wed Jan 23 2013 10:41pm
mjbrr
United Kingdom 2009 Range Rover Sport TDV8 HSE Santorini Black
Nice clear write up Kav.
Looks easy enough Thumbs Up 2009 3.6 TDV8 HSE Santorini Black
Post #370757 Thu Jan 24 2013 12:03am
RobP
As promised here are the details of the adapter lead I have just made up.
Thanks to Kav for his excellent post Thumbs Up You will still need the parts he lists
OBDII USB lead from the great bay of e. (about £7-£8 )
FBH connector pin/wire from the forum shop HERE £1.20
And in addition
2x2 OBDII adaptor. Designed for the older VAG cars to use with the main OBDII USB cable. Mine cost £2 from ebay and came from the same seller as the main lead
A couple of crocodile clips, some wire to extend the cable, a fuse holder (i used a 3amp fuse) a male & female crimp bullet terminal and some heat shrink to keep it all neat.
Tools needed: cutters, ratchet crimpers, soldering iron / solder & multimeter (essential to verify wires to pins your self)
Start with the lead
This is the pin layout
IMPORTANT Exclamation Having made several of the leads now. You MUST verify the lead colors yourself using a multimeter to ensure they go to the correct pins. DO NOT rely on the wire colors in the pictures Thumbs Up
Cut off the black plug and strip outer sleeve (this is for the power connections)
Extend the black and red cables by soldering and covering with heat shrink,
adding the fuse holder to the red 12v+ cable and add the croc clips to the leads
Now cut off white plug and strip a bit of outer sleeve. There are two wires and you will only need the one connected to pin 7 in the main plug.
Using the multimeter I identified this to be the black lead so simply snipped the red lead off. However you should verify this is the right lead your self in case your lead is wired differently Exclamation
I extended the cable by soldering on another small length of wire to which I added the male crimp connector and then heat shrink for neatness
This is the finished item plugged into the OBDII USB
If you follow this part from Kavs instructions to install the single wire from the forum shop
kav1187 wrote:
This is the connector we need to plug our diagnostics port into. The port I've arrowed in the pic is the one we need to stick the red cable into (port 2).
Flip it over so that you can read the port numbers.
Use a paperclip to slide the pink release mechanism to the right.
Insert the paperclip into port 2 and push the rubber bung out.
Take the red cable and insert it into the hole. The spikey bit should face towards the outer face of the connector. You will hear it click when it goes all the way in.
Slide the pink mechanism back to the left to lock the cables in place.
You will be left with this
And the finally add the female crimp terminal to the bare end of that wire. To connect the OBDII lead now all you need to do is attach the croc clip wires to the battery terminals and plug together the male / female connectors Thumbs Up
It was too late to test the lead tonight but I will report back as soon as I have. TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten
Post #370908 Fri Jan 25 2013 12:25am
madmackie
Great post rob Thumbs Up Thumbs Up "Remember its easier to say sorry than it is to get permission " especially off the Mrs !!
Post #370912 Fri Jan 25 2013 12:40am
kav1187
Fantastic write up mate Thumbs Up
Good effort!
When trying to connect to the laptop I found that it worked in this order for me...
1. Connect OBD cable to laptop and install drivers
2. Load Webasto software
3. Wait for car to go into sleep mode (radio screen off, handbrake warning light on dash off) doors closed.
4. Select the correct COM port in the Webasto program
5. Connect cables to battery and heater
6. Start diagnosis
7....watch it hang...close the "initialising WTT window"
8. Start diagnosis
9. Tick on view to see live data.
10. View/clear faults
11. Fuel prime
12. Control>parking heater
13. Enjoy the bonfire Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section Thumbs Up
Post #370913 Fri Jan 25 2013 1:04am
erikh
Norway 2006 Range Rover Sport TDV6 HSE Zermatt Silver
So a really stupid question perhaps - if I buy the Faultmate FCR it will only let me read and clear codes, will that be good enough?
I wouldn't mind buying the parts and such, problem is that I am not THAT handy at soldering etc. so unless someone wants to, provided I transferred the money needed, buy, assemble and post me what is needed - would the Faultmate help?
Erik
Post #370954 Fri Jan 25 2013 5:03pm
