Home > In Car Electronics > Using stock amp with aftermarket head unit |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 |
I have indeed lost access to the settings menu since to need to use the <<and>> to operate it but now thats going to the head unit.
Thu Mar 05 2020 10:35am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4797 |
maybe if you connected the relay pin 86 to the headunit trigger wire, the system may start up without popping. Worth trying.
Thu Mar 05 2020 1:07pm |
Am not gonna lie I am pretty happy it's finally working I don't wanna touch it. The popping I can live with imo.
Thu Mar 05 2020 6:04pm |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 |
Cheers Mate Great to hear you've got things working. I suspect the voice won't work as the settings don't either. I'm being a bit dim on the elctrics can you help confirm my wiring diagram below and point me in the right direction as to which wire exactly I need to connect to to trigger the L7 amp on? Hopefully get this sorted this weekend and then it's the home run on tidying the old girl up.. Cheers Guy 2006 RRS S/C CONSTANTLY under modification... 1994 RRC 4.2l not LSE sadly gone but not forgotten LR Defender 300Tdi - affectionately know as "The Black Beast" |
Mon Mar 09 2020 7:48am |
That wiring diagram looks correct to me AndyK can you confirm?
Mon Mar 09 2020 11:51am |
Cheers mgrover,
Mon Mar 09 2020 12:33pm |
in this image https://imgur.com/a/plc9jTT
Mon Mar 09 2020 12:46pm |
Mon Mar 09 2020 1:07pm |
Thanks Andy K & mgrover,
Tue Mar 10 2020 6:28am |
Guys,
Thu Mar 12 2020 2:52pm |
you still need to complete the circuit with the ground. my head unit had a amp on cable but just connecting to that isn't enough since that is basically just v12 switched on. |
Thu Mar 12 2020 3:15pm |
No this doesn't work, which is why the relay is needed |
Thu Mar 12 2020 7:20pm |
Hi Guys
Sat Aug 08 2020 8:55am |
I think you connect 87 to the wrong wire.
Sat Aug 08 2020 8:58am |
