![]() | Home > In Car Electronics > Using stock amp with aftermarket head unit |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 ![]() ![]() ![]() |
I have indeed lost access to the settings menu since to need to use the <<and>> to operate it but now thats going to the head unit.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5090 ![]() ![]() ![]() |
maybe if you connected the relay pin 86 to the headunit trigger wire, the system may start up without popping. Worth trying.
Am not gonna lie I am pretty happy it's finally working I don't wanna touch it. The popping I can live with imo.
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
Cheers Mate ![]() Great to hear you've got things working. I suspect the voice won't work as the settings don't either. I'm being a bit dim on the elctrics can you help confirm my wiring diagram below and point me in the right direction as to which wire exactly I need to connect to to trigger the L7 amp on? ![]() Hopefully get this sorted this weekend and then it's the home run on tidying the old girl up.. Cheers Guy 2006 RRS S/C CONSTANTLY under modification... 1994 RRC 4.2l not LSE sadly gone but not forgotten LR Defender 300Tdi - affectionately know as "The Black Beast" |
That wiring diagram looks correct to me |
Cheers mgrover,
in this image https://imgur.com/a/plc9jTT
Thanks Andy K & mgrover,
Guys,
you still need to complete the circuit with the ground. my head unit had a amp on cable but just connecting to that isn't enough since that is basically just v12 switched on. |
No this doesn't work, which is why the relay is needed |
Hi Guys
I think you connect 87 to the wrong wire.
