![]() | Home > General > rrs electrical issues |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5136
I would have a look at the wiring in the drivers door hinge area.
| sjfj50 Member Since: 26 Jul 2025 Location: wiltshire Posts: 12
Thanks, I'll check in a moment. |
Checked that cable as best I could and seemed fine. Checked all fuses relays etc and then disconnected battery for about an hour. When reconnected the central display and radio came to life but central locking, wing mirrors adjusters and driver door switch panel still not working. after a few short drivers the central display stopped working again so trying a hard reset again but touching nothing else to see what this does. |
Does the indicator on the door outside flash correctly?
ok, not coming back to life yet. checked everything in the boot, all seems good there. i did notice when i try the central locking there is a click in the boot but none of the locks move.- same if I try the unlock button on the key. |
probably the fuel cap lock making a noise
g |
You were right. I did notice that the near side rear door does try to lock. It is the only door where the catch by the handle moves. |
Where should I look for this? |
OK, took the drivers door card off and there is no power there at all. Assume this is the same with the offside rear door. Where do both doors get power?
Radio - That fuse 68 is only powered when the radio is taken out of standby (by the 'headunit')
Thanks for you reply. Both those fuses are alive and well. Think I need to try to trace the wiring harness to see where the power stops. Need to find out how power gets from these fuses to the doors so I can check connections. |
Well the obvious point is the door connector in the hinge area
Finally had the chance to disconnect the door from the a pillar. There is no power getting to the a pillar. Now need to trace this wire back. Any thoughts on this? |
