Home > General > rrs electrical issues
Probably best easiest to run a new wire across
Use a piggy back fuse
Post #649360 Fri Aug 08 2025 6:58pm
Pistnbroke
United Kingdom 2009 Range Rover Sport TDV6 HSE Galway Green
as an auto electrician with 40 years experience the rule with multiple faults is to pick on one (easy one) and put that right ...that usually sorts the others Always listen to old people or when they die you will live on in ignorance.
The avatar is a picture of the man with a big cock.
Learned to 4x4 on 100 mile beach and Frazer Island QLD
Dont spend money on old cars you will never get it back
Post #649366 Sat Aug 09 2025 8:20am
sjfj50
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Java Black
Sorry for slow updates.
Ok, following Andy K advice I ran a new wire from the original fuse in the cjb round to the drivers door pillar and made a connection there. Hay presto, door switches now all work as does the central locking for some reason.
Now need to sort out why the head unit is blank and have an error code about lost communication with audio unit u0184.
Post #649452 Sun Aug 17 2025 12:23pm
Pistnbroke
..............as does the central locking for some reason...........
Read my post above again and you will understand Always listen to old people or when they die you will live on in ignorance.
Post #649454 Sun Aug 17 2025 1:19pm
Post #649461 Sun Aug 17 2025 9:55pm
sjfj50
Thanks Col
Post #649511 Wed Aug 20 2025 10:36pm
