Home > General > rrs electrical issues
sjfj50
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Java Black
Hi, just purchased a 2010 RRS with a few issues. Strange 1 is the infotainment system is dead, the buttons on the drivers door are dead, the window button on the offside rear door is dead and the doors do not lock but the alarm does set.
Both front and rear nearside windows work from their switches. Any good ideas where to start testing would be much appreciated.
Post #649089 Sat Jul 26 2025 11:14am
I would have a look at the wiring in the drivers door hinge area.
Probably a broken thick wire.
If there are lumps in the wire this could be a break
Post #649090 Sat Jul 26 2025 11:21am
sjfj50
Thanks, I'll check in a moment.
Post #649092 Sat Jul 26 2025 1:46pm
sjfj50
Checked that cable as best I could and seemed fine. Checked all fuses relays etc and then disconnected battery for about an hour. When reconnected the central display and radio came to life but central locking, wing mirrors adjusters and driver door switch panel still not working. after a few short drivers the central display stopped working again so trying a hard reset again but touching nothing else to see what this does.
Post #649102 Sat Jul 26 2025 6:57pm
Does the indicator on the door outside flash correctly?
And does it continue to work when door opened and closed
Post #649105 Sat Jul 26 2025 7:33pm
sjfj50
ok, not coming back to life yet. checked everything in the boot, all seems good there. i did notice when i try the central locking there is a click in the boot but none of the locks move.- same if I try the unlock button on the key.
Post #649114 Sun Jul 27 2025 2:46pm
probably the fuel cap lock making a noise
Thinking about it, i'm probably not that familiar with the electrics on these later models
Post #649115 Sun Jul 27 2025 2:50pm
sjfj50
g
Post #649126 Mon Jul 28 2025 12:20pm
sjfj50
You were right. I did notice that the near side rear door does try to lock. It is the only door where the catch by the handle moves.
Post #649127 Mon Jul 28 2025 12:22pm
sjfj50
Where should I look for this?
Post #649128 Mon Jul 28 2025 12:23pm
sjfj50
OK, took the drivers door card off and there is no power there at all. Assume this is the same with the offside rear door. Where do both doors get power?
While looking into the dead radio, touch screen etc. I discovered there is no power going to fuse 68 so no power coming out! All other fuses do appear to have power. Any idea where fuse 68 gets its power?
Post #649270 Mon Aug 04 2025 1:44pm
Radio - That fuse 68 is only powered when the radio is taken out of standby (by the 'headunit')
Drivers door is powered from fuse 32
rear right door powered from fuse 44
Post #649271 Mon Aug 04 2025 1:57pm
sjfj50
Thanks for you reply. Both those fuses are alive and well. Think I need to try to trace the wiring harness to see where the power stops. Need to find out how power gets from these fuses to the doors so I can check connections.
Post #649274 Mon Aug 04 2025 5:23pm
Well the obvious point is the door connector in the hinge area
See if there is power there.
Post #649276 Mon Aug 04 2025 6:54pm
sjfj50
Finally had the chance to disconnect the door from the a pillar. There is no power getting to the a pillar. Now need to trace this wire back. Any thoughts on this?
Post #649359 Fri Aug 08 2025 6:47pm
