![]() | Home > General > rrs electrical issues |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5105 ![]() ![]() ![]() |
I would have a look at the wiring in the drivers door hinge area.
sjfj50 Member Since: 26 Jul 2025 Location: wiltshire Posts: 7 ![]() ![]() ![]() |
Thanks, I'll check in a moment. |
Checked that cable as best I could and seemed fine. Checked all fuses relays etc and then disconnected battery for about an hour. When reconnected the central display and radio came to life but central locking, wing mirrors adjusters and driver door switch panel still not working. after a few short drivers the central display stopped working again so trying a hard reset again but touching nothing else to see what this does. |
Does the indicator on the door outside flash correctly?
ok, not coming back to life yet. checked everything in the boot, all seems good there. i did notice when i try the central locking there is a click in the boot but none of the locks move.- same if I try the unlock button on the key. |
probably the fuel cap lock making a noise
g |
You were right. I did notice that the near side rear door does try to lock. It is the only door where the catch by the handle moves. |
Where should I look for this? |
