Home > Maintenance & Modifications > Tyre wear advice
Stevepd
Tyre wear advice
Hi folks. I’ve changed over to my summer wheels at the weekend and I can see there is slight wear on the inner quarter of the rear tyres. The car drives fine although I’m going to get them rebalanced. With this being my first tyre change since owning the car, is this how I’d expect to see normal wear?. The wheels are LR 20’s, Pirelli scorpions. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #623240 Wed Mar 30 2022 7:29pm
karlos01
get the tracking done as well had it done on mine as the rears was cutting the inside
Post #623244 Wed Mar 30 2022 8:07pm
knwatkins
Agreed. Definitely worth getting the alignment checked and adjusted as necessary Steve. I use TyreShack in Southampton based on previous forum posts. £50 for a full alignment and great service. If it only needs a single adjustment as my L405 did, it's even cheaper.
Here's my review from when I took the L320 in...
https://www.rrsport.co.uk/forum/post605677.html#605677 Kev
Post #623247 Wed Mar 30 2022 10:28pm
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
Hi Stevepd.
Yes, I'd say tracking is out from your description.
I always get mine done using a Hunter Tracking machine. Much better for 4x4s.
Google 'Hunter Alignment' or have a look at https://www.hunter.com
When I lived in Hampshire I used Flintstones in the SO31 area. Barrie.
2017-Jan 2024: 2005 RRS 2.7TDV6. Best car I ever had - until now!
Current: 2018 Ford Ranger Wildtrak 3.2
Post #623251 Thu Mar 31 2022 6:54am
knwatkins
Same here. TyreShack use Hunter also. Kev
Post #623252 Thu Mar 31 2022 7:14am
Tyrefitter
Definitely a alignment issue,this was mine when it came back from dealers after having rear diff seal fixed under warranty,they had to drop nsr bottom arm to fix.
Before
After results
 Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #623255 Thu Mar 31 2022 8:38am
Stevepd
Thanks everyone. I’ve dropped into my local national who balanced the 4 wheels. The Tyre fitter said that some of the tyres have tyre bounce and are 5 years old. I’ll see what the drive to work is like in the morning for smoothness, but inevitably new tyres are on the horizon. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #623263 Thu Mar 31 2022 6:14pm
