![]() | Home > Maintenance & Modifications > Tyre wear advice |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 ![]() ![]() ![]() |
get the tracking done as well had it done on mine as the rears was cutting the inside |
Agreed. Definitely worth getting the alignment checked and adjusted as necessary Steve. I use TyreShack in Southampton based on previous forum posts. £50 for a full alignment and great service. If it only needs a single adjustment as my L405 did, it's even cheaper.
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
Hi Stevepd.
Same here. TyreShack use Hunter also. Kev
Definitely a alignment issue,this was mine when it came back from dealers after having rear diff seal fixed under warranty,they had to drop nsr bottom arm to fix.
Thanks everyone. I’ve dropped into my local national who balanced the 4 wheels. The Tyre fitter said that some of the tyres have tyre bounce and are 5 years old. I’ll see what the drive to work is like in the morning for smoothness, but inevitably new tyres are on the horizon. 2006 2.7 TDV6 HSE in Cairns Blue. |
