Home > General > That's a first for us
OvalAutos
In all the years and hundreds of TDV6 engines we've stripped down, this is the first time we've ever come across studs being used instead of bolts. Shocked
Is it any wonder the main bearing caps were flopping around in the block, allowing all the bearings to spin.
. Joe
Post #588423 Fri Oct 11 2019 8:29am
aaronjb
Strange - studs are almost always used as an upgrade vs bolts when building high performance engines; they allow a much higher clamping force as the stud is only deformed along one axis (length), while a bolt has to be deformed along two axes (stretched along its length and twisted around its core) to provide the same clamping force..
Of course, as far as I know, ARP don't make a stud kit for JLR engines (at least I can't find one in their catalogue) and studs made of Chineseum-alloy will be much worse than OE bolts.. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #588427 Fri Oct 11 2019 9:37am
OvalAutos
The problem here is that they are too long. The head of the bolts are just protruding past the surface where the sump mates up, like this.
Because they are so long, whoever did this had to remove the splash guard in the sump and even had to cut one of the studs to stop it fouling.
. Joe
Post #588430 Fri Oct 11 2019 10:31am
aaronjb
Ah, see .. now I see the problem! Laughing
Previous receipts from Bodgitandscaper Garages Ltd? Rolling with laughter 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #588432 Fri Oct 11 2019 10:57am
CornishRob
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
O.. Eck ! Just shows that not all engine builders are equal !
Thanks for sharing!
Post #588821 Fri Oct 18 2019 10:50am
