![]() | Home > General > That's a first for us |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 ![]() ![]() |
Strange - studs are almost always used as an upgrade vs bolts when building high performance engines; they allow a much higher clamping force as the stud is only deformed along one axis (length), while a bolt has to be deformed along two axes (stretched along its length and twisted around its core) to provide the same clamping force..
OvalAutos Member Since: 02 Jan 2019 Location: Cradley Heath Posts: 130 ![]() ![]() |
The problem here is that they are too long. The head of the bolts are just protruding past the surface where the sump mates up, like this.
Ah, see .. now I see the problem! |
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 174 ![]() ![]() ![]() |
O.. Eck ! Just shows that not all engine builders are equal !
