![]() | Home > General > Not so bullet proof TDV8 |
A bit surprised the brake pipes are looking dodgy on such a relatively young motor !! |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4463 ![]() ![]() ![]() |
I have sent cars back to a main dealer to have the brake pipes replaced on cars still under the manufacturers 3 year warranty |
The other bit of bad news is....
First off - the corrosion warranty should be explored - its 6 years and usually like to pay on holes rather than what you describe - but worth flagging, you never know on your list
Anti corrosion guarantee is for perforation only. So wont touch it until there are holes.
If they strip your engine right down then surely they will be able to turn whatever they need to turn to gain access. |
This is a dealer Ady. They don't do stripping lol. That's dirty work |
Thats my point - at some point it will come apart ![]() As for the corrosion warranty - i did say about the hole part - but equally i had a defender (new) cleaned, prepared and waxoiled for surface corrosion, no perforations all done under warranty...doesnt hurt to ask/mention etc Mike 2014 Facelift Discovery |
Refuse to get further stressed by the entire episode. Dealer tasked with doing a job and am sure they will
I dont blame you on that score!! Mike
Well...... The new engine and turbos have been fitted |
kp Member Since: 18 Jan 2012 Location: Ex Bashing! Posts: 91 ![]() |
I would honestly get shut of it after all the faults you have been through and crud reading this thread!
Thought about getting rid but heart over rules brain as when this car goes well, it is a pleasure. Not sure why they suffer more than full fat but there is obviously an issue which is why they didn't fit the V8 to facelift models. 2x TDV6. SE and HSE. Both returned to sender with issues👀
The beasty is up and running |
