![]() | Home > General > brake booster fails leak test? |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 ![]() ![]() ![]() |
it does yeah |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5118 ![]() ![]() ![]() |
Did you connect the smoke machine to the engine ?
does 4.2 SC have EGR? I thought that was a diesel thing?
Yeah they do have EGR. It maybe below the throttle
Bled the brakes, all okay I think. Bit unnerving when the abs pump starts to make noise haha
it will have 2 bleed nipples for a reason. (i assume either side)
Well braking feels much better. I've noticed with abs there's a slight lock up then it kicks in. While for other cars I've had it kicks in much faster, that normal? Either way braking is much better and it's all fresh fluid |
