Home > General > brake booster fails leak test? |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 |
it does yeah am slowly running out of ideas. its booked in to have the lambdas replaced either way since they seem to be a ballache without a lift
Sat Aug 08 2020 9:50pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4799 |
Did you connect the smoke machine to the engine ?
Sat Aug 08 2020 9:58pm |
does 4.2 SC have EGR? I thought that was a diesel thing?
Sat Aug 08 2020 10:03pm |
Yeah they do have EGR. It maybe below the throttle
Sat Aug 08 2020 10:26pm |
Bled the brakes, all okay I think. Bit unnerving when the abs pump starts to make noise haha
Sun Aug 09 2020 3:38pm |
it will have 2 bleed nipples for a reason. (i assume either side)
Sun Aug 09 2020 4:01pm |
Well braking feels much better. I've noticed with abs there's a slight lock up then it kicks in. While for other cars I've had it kicks in much faster, that normal? Either way braking is much better and it's all fresh fluid |
Sun Aug 09 2020 5:24pm |
