![]() | Home > General > brake booster fails leak test? |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 ![]() ![]() ![]() |
so ive been getting lean codes for a while now. finally smoke tested brake booster after i figured out how.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5096 ![]() ![]() ![]() |
Well done |
Now I just need to learn to bleed brakes :p |
Ahh things are gonna get real interesting for me since I've got a busy plastic shelf, the lpg reducer and ecu lives their as well haha |
It's split into 2 parts.
So changed everything out, turns out I had a non supercharger brake servo. But I did another smoke test before I installed it, no issues.
Humm.
Aiye I watched both but I just assumed either way it'd be air tight :p I guess when it sucks it'll create an air seal |
when the engine has been running for a bit, disconnect the vac pipe. It should hiss for a good few seconds (and loudly) if its good/new |
My old one hissed for a second at best so I guess we'll see with this new one. Probably means backs to the drawing board on lean codes. Next up, lambda sensors replacement |
I thought petrols used an electric pump on the passenger side to generate vacuum anyway ?
They do yeah, it has a vacuum pump does that mean that it won't affect the amount of oxygen going into combustion?
Well I don’t understand how if you connected a smoke machine to the engine it came out the servo ? |
i connected it to servo directly |
