Home > General > brake booster fails leak test?
Ok. Well if the pipe goes straight over to the pump on the passenger side, so it won’t cause running (lean rich) problems.
Post #602998 Sat Aug 08 2020 8:12pm
mgrover
it does yeah Sad am slowly running out of ideas. its booked in to have the lambdas replaced either way since they seem to be a ballache without a lift
but either way whoever had this car before put in the incorrect brake servo. the one i removed was from a regular RR not a SC RR
Post #603003 Sat Aug 08 2020 9:50pm
Did you connect the smoke machine to the engine ?
Check the EGR is Bolted on tight
Post #603004 Sat Aug 08 2020 9:58pm
mgrover
does 4.2 SC have EGR? I thought that was a diesel thing?
And yeah I did, I pumped smoke thought intake and valve cover breather and no leaks from either of them
edit: theres a tiny leak from the airbox, but thats before the MAF sensor, so i assume itd be metered air, not unmetered.
edit2: the only thing is when the engine is off, is the throttle open? otherwise I assume if its closed then smoke is going nowhere?
Post #603005 Sat Aug 08 2020 10:03pm
Yeah they do have EGR. It maybe below the throttle
Yeah the throttle would be closed. The other side is much more sensitive to leaks
One of the cam cover breathers May go to that side of throttle. Have a look
Post #603006 Sat Aug 08 2020 10:26pm
mgrover
Bled the brakes, all okay I think. Bit unnerving when the abs pump starts to make noise haha
Only thing is I've got the brembo brakes which has two bleed screws but I only bled from one. The iid tool didn't say anything about bleeding from both, will it of bleed both sets of pistons?
Post #603034 Sun Aug 09 2020 3:38pm
it will have 2 bleed nipples for a reason. (i assume either side)
as you haven't messed with the calipers you may get away with it
Post #603037 Sun Aug 09 2020 4:01pm
mgrover
Well braking feels much better. I've noticed with abs there's a slight lock up then it kicks in. While for other cars I've had it kicks in much faster, that normal? Either way braking is much better and it's all fresh fluid Very Happy
Post #603042 Sun Aug 09 2020 5:24pm
