Home > In Car Electronics > Using stock amp with aftermarket head unit |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 |
Anyone seen or used this before?
Sun Jan 12 2020 3:31pm |
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 |
Looks good although only has one set of RCA inputs so not sure how you could get front to rear fading and sub level control TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten |
Sun Jan 12 2020 10:20pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
Use two of these?? - one for the front and one for the back speakers. But then good amps are not all that expensive so just replace the OEM amp under the seat with one that will power the speakers with input from the new head unit. Garry 07MY RRS TDV6 Arctic Frost Aspen Interior |
Mon Jan 13 2020 1:30am |
Don't think two are an option as the amp only has one MOST input
Mon Jan 13 2020 9:29am |
am not the audiophile you guys seem to think i am the dog usually sits in the boot and 99% of the time the music is played for the driver.
Mon Jan 13 2020 10:05am |
Fair enough. Would be good to post a review on it once you have fitted it TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten |
Mon Jan 13 2020 10:26am |
ill probably try make a video series out of it. its been hard to find resources for the L320 in terms of head units.
Mon Jan 13 2020 10:34am |
shameless bump, its all hooked up with a screen retention kit to boot.
Thu Feb 20 2020 7:14pm |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 |
Hmmm,
Fri Feb 21 2020 6:57pm |
thats the results page https://www.rrsport.co.uk/forum/topic55744.html
Mon Feb 24 2020 10:32am |
Mon Feb 24 2020 10:45am |
I think in your case you connect that remote on from your head unit to the MOST interface. Since it'll power on the amp via fibre optic. I think my setup just bypasses the headunit and goes directly to the lighter, bit more caveman but yah. |
Mon Feb 24 2020 10:59am |
I've figured out the problem your having, the network breaks when the head unit is unplugged because the upper screen isn't powered on. Mine worked because I have the screen retention kit which keeps the head unit powering on. But steering wheel controls don't work in my setup because the stock head unit captures them
Fri Feb 28 2020 12:41am |
Thanks Mate for all the help.
Fri Feb 28 2020 8:48am |
