Home > In Car Electronics > Using stock amp with aftermarket head unit |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4777 |
Can u take another clear picture of the LR connector. |
Sat Aug 08 2020 9:05am |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 |
It's the same wire as per MrRovers post here:
Itβs meant to be ground. 0v
Sat Aug 08 2020 9:12am |
You should also hear a click from behind the glovebox at the same time as the other click |
Sat Aug 08 2020 9:30am |
I was getting that.
Sat Aug 08 2020 9:34am |
well if fuse 57 and 58 (behind glovebox) have power on them (when relay clicks), this mod is working |
Sat Aug 08 2020 9:53am |
If the amp isn't working the things to consider are:
Sat Aug 08 2020 10:01am |
Ok, following your numbering:
Sat Aug 08 2020 10:04am |
So.... It works ππΌ
Sat Aug 08 2020 10:39am |
Spoke too soon. Fire it up again and nothing...
Sat Aug 08 2020 10:51am |
Ok, my bad looks like I have a wonky connection to the FO control box π€¦π€¦
Sat Aug 08 2020 11:25am |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 |
a bit more info on my part, sometimes 1/10 times the amp doesnt turn on. i turn the car off, turn it back on and hey presto works fine. no idea why.
Mon Aug 10 2020 3:25pm |
