Home > General (L494) > Sunroof drains
Ironhorse
yes mate
the only 2 drains i can find are around the "B" pillar
they exit under the rear wheel arch 2014 L494 5.0 SC
2014 L538 2.2 SD4
Post #650008 Tue Sep 30 2025 9:26pm
Ade RRS
Thanks mate, just located them.
Good news is they are still draining, bad news is I can see from the top they are beginning to corrode!
Just now need to decide on if I have a go myself or ask my local indie to swap the steel tube.
I wonder if some rust eater in the top would prelong their life?
Not sure I fancy pulling on the headliner or pulling strips off the roof!
Post #650009 Tue Sep 30 2025 10:23pm
Ironhorse
Easy job to get trim off roof for access, mine was starting to rust but not to bad(14 plate l494)
I used a Wire bottle brush on a drill inside the tube to clean any surface rust off,then a small bit of sponge on a stick to apply a few coats of rust eater,then when dry applied some stone chip with the same sponge on a stick
Got wifey to put around a gallon of water down each tube as I checked up the headlining
Half a day .sorted 2014 L494 5.0 SC
2014 L538 2.2 SD4
Post #650012 Wed Oct 01 2025 7:49am
Ade RRS
Thanks @ironhorse, super helpful post!
Post #650018 Wed Oct 01 2025 9:46am
41jules1967
Did mine today
https://www.rrsport.co.uk/forum/post650085.html#650085 2021 L494 D300MHEV Autobiography
2019 Discovery Sport D180 HSE
Post #650086 Sat Oct 04 2025 4:49pm
Woppyman
United Kingdom 2012 Range Rover Sport Supercharged Autobiography Siberian Silver
Same here. Rustproofed and hammerite. One of those jobs where preventative is better than remedial. Evoque HSE Dynamic
5.0 Charger MY12
Post #650215 Wed Oct 15 2025 8:59pm
RRT
I have done mine today - a very easy job* used a stainless insert ( https://www.ebay.co.uk/itm/334158179851 ) and JB Weld to epoxy in place. I also used rust converter (Jenolite) first although there was no real sign of any corrosion (I live within half a mile of the sea so was very surprised).
* don't do what I did and remove the outer panel strip on one side it is a bar-steward to get back on and stay flush on the forward edge and I need to get some replacement clips Big Cry Whistle MY17 RRS 4.4d V8 Autobiography - Aintree Green (also referred to on Topix as British Racing Green)
Post #650236 Fri Oct 17 2025 2:08pm
41jules1967
did you not look at the pics?
Post #650237 Fri Oct 17 2025 2:12pm
RRT
Yes and then promptly had (costly) brain fade. Rolling Eyes MY17 RRS 4.4d V8 Autobiography - Aintree Green (also referred to on Topix as British Racing Green)
Post #650238 Fri Oct 17 2025 2:34pm
