Home > General (L494) > Sunroof drains
Ironhorse
yes mate
the only 2 drains i can find are around the "B" pillar
they exit under the rear wheel arch 2014 L494 5.0 SC
2014 L538 2.2 SD4
Post #650008 Tue Sep 30 2025 9:26pm
Ade RRS
Thanks mate, just located them.
Good news is they are still draining, bad news is I can see from the top they are beginning to corrode!
Just now need to decide on if I have a go myself or ask my local indie to swap the steel tube.
I wonder if some rust eater in the top would prelong their life?
Not sure I fancy pulling on the headliner or pulling strips off the roof!
Post #650009 Tue Sep 30 2025 10:23pm
Ironhorse
Easy job to get trim off roof for access, mine was starting to rust but not to bad(14 plate l494)
I used a Wire bottle brush on a drill inside the tube to clean any surface rust off,then a small bit of sponge on a stick to apply a few coats of rust eater,then when dry applied some stone chip with the same sponge on a stick
Got wifey to put around a gallon of water down each tube as I checked up the headlining
Half a day .sorted 2014 L494 5.0 SC
2014 L538 2.2 SD4
Post #650012 Wed Oct 01 2025 7:49am
Ade RRS
Thanks @ironhorse, super helpful post!
Post #650018 Wed Oct 01 2025 9:46am
41jules1967
Did mine today
https://www.rrsport.co.uk/forum/post650085.html#650085 2021 L494 D300MHEV Autobiography
2019 Discovery Sport D180 HSE
Post #650086 Sat Oct 04 2025 4:49pm
