Home > General > Safety Recall - N923 - Tow Ball Retaining Bracket Kit
Eaters
I received a letter addressed personally to me from JLR regarding this. Searching around I see comments on the Disco 3 forum to the similar effect but from 2015!!!
The letter starts " A concern has been identified relating to the instructions provided on the method of use of Land Rover branded and aftermarket specification detachable tow balls used on certain Range Rover Sport Vehicles from 2006 model year to 2013 model year, and Discovery 3 and Discovery 4 vehicles from 2005 model year to 2016 model year. There is inadequate warning of risk of using the tow ball incorrectly. Instructions in the owner's manual specify that the tow ball should be removed and stowed when not in use."
The Gov.uk web site confirms that my car has a safety recall outstanding against it
I plan to contact my Indy to discuss but it does seem that the whole thing, if required(!?!) is free of charge.
Has anyone else had this recall? The full letter is in My Gallery in the JLR Recall Notice entitled the same as the subject line for this post. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #648769 Thu Jul 10 2025 4:44pm
daxmatt
Yep, had it yesterday
Post #648770 Thu Jul 10 2025 8:51pm
I have a Tow Trust bar fitted which bolts in to the receiver and has legs bolted back to the chassis, so even if I get the letter, I don't think I'll be going to a LR dealership. Laughing 2012 SDV6 - it's missing a couple of cylinders
Post #648784 Sat Jul 12 2025 12:54pm
Meshan
I had the letter.
Do I get a free tow bar? L320 Range Rover Sport 2008
3.6 TDV8
Remap
EGR Blank
Post #648786 Sat Jul 12 2025 4:23pm
Disco_Mikey
No, you get a steel bracket, some nuts and bolts and a spanner Laughing
Post #648787 Sat Jul 12 2025 6:44pm
Meshan
You can never have too many spanners L320 Range Rover Sport 2008
3.6 TDV8
Remap
EGR Blank
Post #648789 Sat Jul 12 2025 9:18pm
https://accessories-instructions.landrover...0/G3356337
That just looks like a "Posh" version of this, been around for years. Smile
Post #648792 Sat Jul 12 2025 10:22pm
The finish looks like it's cast. So that'll be as strong as an ox then... 2012 SDV6 - it's missing a couple of cylinders
Post #648803 Sun Jul 13 2025 6:25pm
Eaters
I'm booked into a 20 minutes slot at the main dealers (Harwoods Brighton) tomorrow. It sounds like I take the car to them, they have a look, give me a new spanner (and some other bits), I drive away, I fit it myself.
Have I got that right? Shocked Robin
Gone:
MGZTT 190 2.5
Post #648812 Mon Jul 14 2025 9:12am
The Range Rover
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Stornoway Grey
Hi All
Just got my Safety Recall yesterday, Im a bit miffed at this ait will be a lot of farting about getting the tow ball off and on now!
I loved the fact that you could remove the tow bar and keep the lines of the car "clean".
Does anyone know how long they have known about this issue? as I have been towing my expensive caravan about for a few years now, and the hitch could have uncoupled at any time! Censored
Not a happy chappy! Censored
Post #648845 Tue Jul 15 2025 8:33am
There was a recall around 2015 to check for excessive wear etc. if I remember right, had some sort of gauge to check it at dealers.
Very technical piece of kit Rolling with laughter
Post #648846 Tue Jul 15 2025 8:53am
Eaters
I got my kit today. No instructions. No guide to fitting. When to use? OK so I am being a bit unkind as you can work out most of it if you have reasonable intelligence. But I wonder what the average 80 year old will do (I'm 72) as I expect that they don't want to be rolling around under the back of the car each time they fit the tow bar. So I guess either they will not bother with the new kit, or they will fit it once and the removable tow bar becomes a fixed tow bar - but without the strength! Robin
Gone:
MGZTT 190 2.5
Post #648852 Tue Jul 15 2025 1:23pm
Wonder if I will get the recall notice now the car is on the other side of the world with a different reg. no. Rolling with laughter
If you click on the link in my earlier post it does actually give you the fitting instructions if needed, or below albeit the USA version, I'm sure it will be the same.
Link to animated video instruction's although it is a bit slow to load at times. https://animations.cloudproduct.info/bracket/
Post #648859 Tue Jul 15 2025 10:10pm
garrycol
Australia
I find it amazing that Australian cars do not have a recall even though the mechanism of plugging into the rear X member is the same, as is the lock - and our system has a much higher down force rating (the actual tow bar is different). There have been instances of the tow bar falling out but mainly due to "pilot error". 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #648861 Wed Jul 16 2025 7:58am
Eaters
Cheers Col Robin
Gone:
MGZTT 190 2.5
Post #648862 Wed Jul 16 2025 8:53am
