![]() | Home > General > Safety Recall - N923 - Tow Ball Retaining Bracket Kit |
| Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1559
I received a letter addressed personally to me from JLR regarding this. Searching around I see comments on the Disco 3 forum to the similar effect but from 2015!!!
| daxmatt Member Since: 16 Aug 2014 Location: kent Posts: 219 |
Yep, had it yesterday |
| Meshan Member Since: 19 Oct 2024 Location: Northampton Posts: 89
I had the letter.
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4519
No, you get a steel bracket, some nuts and bolts and a spanner |
You can never have too many spanners L320 Range Rover Sport 2008
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5124
https://accessories-instructions.landrover...0/G3356337
| RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9120
The finish looks like it's cast. So that'll be as strong as an ox then... 2012 SDV6 - it's missing a couple of cylinders
I'm booked into a 20 minutes slot at the main dealers (Harwoods Brighton) tomorrow. It sounds like I take the car to them, they have a look, give me a new spanner (and some other bits), I drive away, I fit it myself.
| The Range Rover Member Since: 25 Jan 2010 Location: Whitburn Posts: 51
Hi All
There was a recall around 2015 to check for excessive wear etc. if I remember right, had some sort of gauge to check it at dealers.
I got my kit today. No instructions. No guide to fitting. When to use? OK so I am being a bit unkind as you can work out most of it if you have reasonable intelligence. But I wonder what the average 80 year old will do (I'm 72) as I expect that they don't want to be rolling around under the back of the car each time they fit the tow bar. So I guess either they will not bother with the new kit, or they will fit it once and the removable tow bar becomes a fixed tow bar - but without the strength! Robin
Wonder if I will get the recall notice now the car is on the other side of the world with a different reg. no. |
| garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071
I find it amazing that Australian cars do not have a recall even though the mechanism of plugging into the rear X member is the same, as is the lock - and our system has a much higher down force rating (the actual tow bar is different). There have been instances of the tow bar falling out but mainly due to "pilot error". 07MY RRS TDV6
Cheers Col Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
