Home > Technical > Coolent level low light on |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4865 |
There is no float listed separate for the for the tank, so if there is a actual float it is a integral part of the tank, I imagine the push in sensor picks up a signal from the float in some way which seem a little complex way of doing it, as the only electrical connection/plug appears to be just to the sensor, but based on the construction and shape of the tank not sure where the float would actually be located in the tank
Fri Aug 04 2023 10:58pm |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 431 |
At the very bottom of it. You can see it pretty well in this picture.
Sat Aug 05 2023 6:29am |
That is the push in sensor not a float.
Sat Aug 05 2023 6:38am |
Ah, I see the sensor probe bit must go through the middle of it, that makes more sense how it would work, and would explain why it is integral with the tank.
Sat Aug 05 2023 6:46am |
Iomegas Member Since: 16 Nov 2020 Location: Newcastle Upon Tyne Posts: 206 |
Yea bloody annoying tank design on my old tank it was free to move I could hear it bouncing around when drained and off the car but it must have gone bad absorbing the water and sinking. |
Sat Aug 05 2023 6:50am |
These manufactures slogan must be "Why make thing simple when they can be made expensive and complicated".
Sat Aug 05 2023 6:59am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4806 |
The advantage of this method is that there is no way the sensor can cause a leak. So clever.
Sat Aug 05 2023 10:59am |
Barry webb Member Since: 01 Jun 2023 Location: Cornwall Posts: 10 |
Thank you all very much for your sound advice I now understand how it works thanks to you guys.
Sat Aug 05 2023 4:41pm |
