Home > Technical > Coolent level low light on
There is no float listed separate for the for the tank, so if there is a actual float it is a integral part of the tank, I imagine the push in sensor picks up a signal from the float in some way which seem a little complex way of doing it, as the only electrical connection/plug appears to be just to the sensor, but based on the construction and shape of the tank not sure where the float would actually be located in the tank
Post #634823 Fri Aug 04 2023 10:58pm
NoExpert
At the very bottom of it. You can see it pretty well in this picture.
 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #634825 Sat Aug 05 2023 6:29am
That is the push in sensor not a float.
Post #634826 Sat Aug 05 2023 6:38am
Iomegas
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi if you look closely you can see the float as mentioned it’s the light brown colour at the bottom you can see.
Post #634827 Sat Aug 05 2023 6:41am
Ah, I see the sensor probe bit must go through the middle of it, that makes more sense how it would work, and would explain why it is integral with the tank.
Post #634828 Sat Aug 05 2023 6:46am
Iomegas
Yea bloody annoying tank design on my old tank it was free to move I could hear it bouncing around when drained and off the car but it must have gone bad absorbing the water and sinking.
Post #634829 Sat Aug 05 2023 6:50am
These manufactures slogan must be "Why make thing simple when they can be made expensive and complicated". Laughing
Post #634830 Sat Aug 05 2023 6:59am
The advantage of this method is that there is no way the sensor can cause a leak. So clever.
Bad point is you can’t change the float.
Bmw and jaguar both use this method. Though you can usually prod the float on these
There is a magnet as part of the float.
The sensor is a reed switch to sense the magnet
Post #634833 Sat Aug 05 2023 10:59am
Barry webb
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
Thank you all very much for your sound advice I now understand how it works thanks to you guys.
I will order a new tank and report back.
Post #634843 Sat Aug 05 2023 4:41pm
