![]() | Home > Technical > Fog lights |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156
Should see something like this under the fuse box lid.
| Clowesd Member Since: 24 Mar 2022 Location: West sussex Posts: 10
Old thread i know but did you resolve this ? Im having the exact same problem |
Did you manage to fix this issue ? Mine is the same both no power at either fuses, no fog light symbol on the dash either and i think there should be ? |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5147
Front and rear not working ?
Thanks for the reply, both the front and rear not working |
There is a fuse under the bonnet that needs checkin fuse numbe 2 |
I have checked all fuses in bonnet area and all are ok |
For 2005-2009 models
Thanks for the info Andy, i have pulled all the fuses in the engine bay with clear tops, there is no power at all at the brown and purple thick wire behind the switch any other ideas what it could be ? |
Causing an MOT failure is it ?
Yes its due an m.o.t. not worried about the fronts |
Under the bonnet is a square relay R13 (with key icon)
Thanks very much ile give it a go and report back |
| All times are GMT |
