Home > Technical > Fog lights
Page 2 of 3 <123>
B9BS X wrote:
Andy K wrote:
The fuse or link in the top left (purple wire) was the one I was thinking of.
do u know what fuse number that would be please?
One of the large fuses under the bonnet, number 2
Post #615082 Wed Jun 23 2021 8:33am
Should see something like this under the fuse box lid.
Post #615083 Wed Jun 23 2021 8:52am
Clowesd
Old thread i know but did you resolve this ? Im having the exact same problem
Post #623082 Thu Mar 24 2022 5:34pm
Clowesd
Did you manage to fix this issue ? Mine is the same both no power at either fuses, no fog light symbol on the dash either and i think there should be ?
Post #623083 Thu Mar 24 2022 5:36pm
Front and rear not working ?
What fuse has no power ?
Yes there should be green (front) and orange (rear) lights on dash
Post #623086 Thu Mar 24 2022 6:46pm
Clowesd
Thanks for the reply, both the front and rear not working Sad i have checked and there is no power to fuse f38 and f32 behind the glove box
Post #623089 Thu Mar 24 2022 7:31pm
There is a fuse under the bonnet that needs checkin fuse numbe 2
Post #623090 Thu Mar 24 2022 8:12pm
Clowesd
I have checked all fuses in bonnet area and all are ok
Post #623091 Thu Mar 24 2022 8:38pm
For 2005-2009 models
So its a large fuse under the bonnet, with a window in the top.
If that is ok, remove the headlight switch. This is done by pulling on the surrounding black/beige trim
Check the thick brown/purple wire has power on it, when the ignition is on. (pin Xr) (if no, recheck the fuse under bonnet)
Activate the fog lights, and check you have power coming out the switch (pins 83) on the wires :
blue/red (front)
red/orange (rear)
Post #623100 Fri Mar 25 2022 12:11pm
Clowesd
Thanks for the info Andy, i have pulled all the fuses in the engine bay with clear tops, there is no power at all at the brown and purple thick wire behind the switch any other ideas what it could be ?
Post #623104 Fri Mar 25 2022 2:37pm
Causing an MOT failure is it ?
Are the front fogs Essential to function ?
Post #623105 Fri Mar 25 2022 2:42pm
Clowesd
Yes its due an m.o.t. not worried about the fronts
Post #623106 Fri Mar 25 2022 3:38pm
Under the bonnet is a square relay R13 (with key icon)
Give it a wiggle/remove with front fogs on.
See if that makes them work.
If not fit a spare relay. Try swapping the rear heater relay into it. The one with the wavy lines at the rear.
r10. It’s not used on the RRS
Post #623109 Fri Mar 25 2022 4:18pm
This is the layout on lid.
The one marked Fog in red.
You can borrow the one marked DRL
Post #623110 Fri Mar 25 2022 4:58pm
Clowesd
Thanks very much ile give it a go and report back
Post #623112 Fri Mar 25 2022 5:01pm
Page 2 of 3 <123>
