Home > Faults & Fixes > Unidentified leak |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4335 |
Fuel filter lives in that area |
Tue Jun 08 2021 2:53pm |
ARB pipes possibly? Is the liquid oil like or petrol like? 2012 5.0 SC AB
Tue Jun 08 2021 3:00pm |
tess Member Since: 20 Feb 2020 Location: sheffield Posts: 30 |
The fluid isn't a rainbow more like oil |
Tue Jun 08 2021 3:07pm |
The leak maybe from the rear diff, is that just seals? |
Wed Jun 09 2021 9:13pm |
Seatown Member Since: 15 Mar 2019 Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands Posts: 100 |
What does it smell like? If diesel rather than oil then as Disco Mikey says the fuel filter is under there or alternatively it may be a leak from the FBH pump or pipework which is nearby, slightly in front of the drivers seat and towards the middle. I had a leak from there although in your case the Fuel Burning Heater pump shouldn't be working in the summer so less likely! 2010 TDV8 - current - my first RRS, loving it so far......
Wed Jun 09 2021 9:46pm |
That’s just a little distance from the drivers seat area! 2012 5.0 SC AB Mods: TPMS Genuine LR DRLs Remote Boot close from key fob 2016 Discovery 4 Mirrors AKA RRS2 2014 L405 Surround Camera retro fit (WIP) 2013 RRS Dual View Screen fit (Complete) 2016 LR4 RSE 2014 LR4 Homelink 2016 FFRR Electrochromatic Wing Mirror Glass 70 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
Wed Jun 09 2021 10:49pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8841 |
It's not just condensate from the air conditioning, is it? 2012 SDV6 - it's missing a couple of cylinders
Thu Jun 10 2021 1:37pm |
If it was condensate, wouldn't it evaporate in this weather & the fluid feels like oil in my fingers |
Thu Jun 10 2021 7:47pm |
If it's oily, it's either fuel or dynamic response fluid. Fuel has an obvious smell, dynamic response fluid isn't smelly in small amounts.
Thu Jun 10 2021 8:35pm |
The oil leak is from the rear diff area, is this a repair or replacement |
Wed Jun 16 2021 11:52am |
Mystery solved, the rear anti roll bar is leaking. |
Tue Jun 22 2021 4:33pm |
