![]() | Home > General > my dilemma (and how can i resolve it) |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5117 ![]() ![]() ![]() |
Without a doubt remove the head yourself is the sensible way forward.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4521 ![]() ![]() ![]() |
Could also be an EGR cooler |
loonyball Member Since: 29 May 2019 Location: ballymena Posts: 30 ![]() ![]() ![]() |
yeah, i think it is for sure the way to go, i guess its just having the confidence to get stuck in, i've read countless times how some consider replacing egr valves and coolers a big deal, i have replaced them myself on this car and a previous disco without too much faff.... |
oh if only.... i've been chasing this issue for several months, i changed both egr's and coolers a couple of months ago, weirdly, the car still drives fine, no overheating, no white smoke, no water in oil-oil in coolant etc... only real symptoms are poor heater, and serious amount of air returning to expansion tank, i was checking all the pipework, and the thermostats in the egr coolers yesterday and just thought i would run another sniff test and sure enough, it turned green... and so did i at the same time ![]() |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9128 ![]() ![]() ![]() |
Search for member Naks on here. In his signature there is a link to the workshop manual if you don't already have it. |
thanks lads, going to have to do a bit of research and break out the halyards socket set, my hammer and a six pack |
You will need something heavy duty for head bolts and a scaffold bar. |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 ![]() ![]() |
So .. you're saying he needs the big hammer? |
