![]() | Home > Technical > 2012 (single/ one piece) tailgate opening/ closing problems |
What happens if (when the tail gate stops and begins to drop) you push the tail gate up manually until it stops? Does it drop again? 2019 5.0 SC SVA (Current)
Cymru001 Member Since: 07 Aug 2019 Location: Newport, South Wales Posts: 33 ![]() ![]() ![]() |
It does drop again. Whether I stop it dropping and push it all the way up or I wait for it to finish dropping then raise, it just lowers itself back to a 12" gap. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5150 ![]() ![]() ![]() |
Certainly no expert, but the sounds a bit like a internal leak within the ram to me, maybe a seal or valve of some sort leaking back past or possibly if they are gas the gas has leaked out in some way rather than electrical issue but only a guess, don't think it should be showing any chrome either or mine certainly don't. Myself I think I would be trying a new ram unfortunately they are not cheap but Island 4x4 were doing genuine one's for £150.00 + vat. as compared to dealers at around £230.00 only a suggestion though.
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 479 ![]() ![]() |
Not sure it will help but it sounds like it is lowering itself to a pre set height,
I think the OP has tried to reset it already. It does sound like the struts are failing, my Sept 11 (12MY) had its struts replaced by the dealer (at a fair old cost) in 2014 so the original set only lasted 2 years! The cars now over 8 years old on that second set. 2019 5.0 SC SVA (Current)
Silverstone Member Since: 04 Sep 2014 Location: Towcester Posts: 184 ![]() ![]() ![]() |
Had mine replaced at dealer on my MY2013 L320 last month. Even with staff discounts cost £365. Both should be done at the same time and takes technicians about 20 mins to recalibrate (apparently). There is no replacement for displacement - W O Bentley
Call me cynical but, I think the "recalibrate" is the expensive name for holdng the tailgate in the required position and press button until car "beeps". |
Probably a screw thread made of cheese. 2019 5.0 SC SVA (Current)
The struts were the problem!!
Probably not the cheapest struts out there but the link is -
Seems like a fair price for a pair of the struts, probably be that for just one at L/R.
Stavroskon Member Since: 02 Dec 2021 Location: Athens Posts: 7 ![]() ![]() ![]() |
In my rrs 2013 after struts replacing with aftermarkets eBay … the tailgate open and close without pressing button for seconds time… any suggestions??? |
pomistea Member Since: 03 Jun 2021 Location: Dublin Posts: 48 ![]() ![]() ![]() |
I'm having a similar problem.
