Home > Technical > 2012 (single/ one piece) tailgate opening/ closing problems
Cymru001
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Stornoway Grey
Hi all,
I have found many posts and responses which relate to tailgate problems, but none which relate directly to my particular problem.
If I use either the fob or tailgate button, the tailgate will open fully then slowly sink until its only open about 12". If I use the button in the dash, the tailgate will open fully and stay there.
Additionally, the close button located in the tailgate, does not work however the boot is opened or at whatever position it comes to rest.
I am also getting what sounds like a small, dull thud when I manually close the tailgate. I can't see any obvious touch/ wear marks but feel there is a part of the tailgate which is being fouled somewhere during the closing operation (the noise happens immediately before the gate latches closed).
I suspect the fault lies with the struts as the passenger side is completely enclosed and the driver side has a little of the chrome 'ram' showing. Also, when the tailgate is closed, the driver side part of the tailgate stands off slightly. Would the struts cause there to be a larger gap on the drivers' side or is this a hinge alignment/ adjustment issue?
I've tried the reset option whilst holding the tailgate up but this has no effect.
Has anyone had this problem and know what the cause is? If I were to swap out the struts, are they plug and play or would I need to get them coded to the car? Has anyone tried to adjust the tailgate to remedy the shut line/ gap issues?
Any help would be appreciated.
Post #592882 Sun Jan 05 2020 11:31pm
Brit Plumber
What happens if (when the tail gate stops and begins to drop) you push the tail gate up manually until it stops? Does it drop again? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #592903 Mon Jan 06 2020 2:31pm
Cymru001
It does drop again. Whether I stop it dropping and push it all the way up or I wait for it to finish dropping then raise, it just lowers itself back to a 12" gap.
Post #592904 Mon Jan 06 2020 2:35pm
Certainly no expert, but the sounds a bit like a internal leak within the ram to me, maybe a seal or valve of some sort leaking back past or possibly if they are gas the gas has leaked out in some way rather than electrical issue but only a guess, don't think it should be showing any chrome either or mine certainly don't. Myself I think I would be trying a new ram unfortunately they are not cheap but Island 4x4 were doing genuine one's for £150.00 + vat. as compared to dealers at around £230.00 only a suggestion though.
Post #592938 Mon Jan 06 2020 10:14pm
Autobiography1969
Not sure it will help but it sounds like it is lowering itself to a pre set height,
the following shows how to reset the height you want..
wrong model but the process works..
May help may be of no use at all, but free and easy to check..
GL ===========================================
2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar,
Post #592991 Tue Jan 07 2020 9:52pm
Brit Plumber
I think the OP has tried to reset it already. It does sound like the struts are failing, my Sept 11 (12MY) had its struts replaced by the dealer (at a fair old cost) in 2014 so the original set only lasted 2 years! The cars now over 8 years old on that second set. 2019 5.0 SC SVA (Current)
Post #592993 Tue Jan 07 2020 10:44pm
Silverstone
United Kingdom 2012 Range Rover Sport Supercharged HSE Baltic Blue
Had mine replaced at dealer on my MY2013 L320 last month. Even with staff discounts cost £365. Both should be done at the same time and takes technicians about 20 mins to recalibrate (apparently). There is no replacement for displacement - W O Bentley
MY2013 5.0 Supercharged HSE L320
Post #593000 Wed Jan 08 2020 12:30am
Call me cynical but, I think the "recalibrate" is the expensive name for holdng the tailgate in the required position and press button until car "beeps". Smile
Found this as well, it would appear the struts are not gas or oil a I thought they might be but, basicaly a rotating screw thread operated by a electrical motor to lift the tailgate up and down.
Post #593001 Wed Jan 08 2020 1:10am
Brit Plumber
Probably a screw thread made of cheese. 2019 5.0 SC SVA (Current)
Post #593004 Wed Jan 08 2020 9:04am
Cymru001
2012 (single/ one piece) tailgate problems - SORTED
The struts were the problem!!
No prizes for guessing what's wrong with that picture.
I bought new ones from Ebay and they took about half an hour to fit. The biggest problem was finding something to prop the tailgate open so I could do the work.
Whilst I had the panel off the inside tailgate, I also fitted the unit which now means I can close the tailgate from the fob or the button inside the car.
One happy chappy Very Happy Thumbs Up
Post #595274 Thu Feb 20 2020 11:35pm
Thumbs Up If the new struts were a good price might be worth adding a link to them as may be of use to other members.
Post #595275 Thu Feb 20 2020 11:42pm
Cymru001
Probably not the cheapest struts out there but the link is -
https://www.ebay.co.uk/itm/2X-GAS-SPRING-S...SwYjRd86Z1
The tailgate gizmo (Also mentioned in other posts on this forum) -
https://www.ebay.co.uk/itm/Range-Rover-Evo...2749.l2649
Post #595280 Fri Feb 21 2020 12:25am
Seems like a fair price for a pair of the struts, probably be that for just one at L/R.
Post #595281 Fri Feb 21 2020 12:40am
Stavroskon
Greece 2013 Range Rover Sport SDV6 HSE Santorini Black
In my rrs 2013 after struts replacing with aftermarkets eBay … the tailgate open and close without pressing button for seconds time… any suggestions???
Post #619763 Sun Dec 05 2021 9:59am
pomistea
Ireland 2013 Range Rover Sport 3.0 TDV6 HSE Fuji White
I'm having a similar problem.
When I press the button either in the car or on the fob, the boot opens about halfway, then stops.
If I press the button a second time, it then continues and opens fully.
I tried resetting by holding the close button when the boot is fully open. I get a beep after about 5 seconds but it doesn't fix the problem.
Any ideas?
Post #649629 Wed Sep 03 2025 8:46pm
