![]() | Home > Technical > 2012 (single/ one piece) tailgate opening/ closing problems |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5150 ![]() ![]() ![]() |
Do you manually lift it to the fully open position and then hold it and press the close button until the beep?
pomistea Member Since: 03 Jun 2021 Location: Dublin Posts: 48 ![]() ![]() ![]() |
Hi Col.
Just out of interest do you have any fault codes showing, believe it or not there are 31 fault codes listed which are associated with the one piece rear tailgate, just thought it may give a clue if there is.
