Home > Technical > 2012 (single/ one piece) tailgate opening/ closing problems |
What happens if (when the tail gate stops and begins to drop) you push the tail gate up manually until it stops? Does it drop again? 2012 5.0 SC AB
Mon Jan 06 2020 2:31pm |
Cymru001 Member Since: 07 Aug 2019 Location: Newport, South Wales Posts: 27 |
It does drop again. Whether I stop it dropping and push it all the way up or I wait for it to finish dropping then raise, it just lowers itself back to a 12" gap. |
Mon Jan 06 2020 2:35pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4847 |
Certainly no expert, but the sounds a bit like a internal leak within the ram to me, maybe a seal or valve of some sort leaking back past or possibly if they are gas the gas has leaked out in some way rather than electrical issue but only a guess, don't think it should be showing any chrome either or mine certainly don't. Myself I think I would be trying a new ram unfortunately they are not cheap but Island 4x4 were doing genuine one's for £150.00 + vat. as compared to dealers at around £230.00 only a suggestion though.
Mon Jan 06 2020 10:14pm |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 466 |
Not sure it will help but it sounds like it is lowering itself to a pre set height,
Tue Jan 07 2020 9:52pm |
I think the OP has tried to reset it already. It does sound like the struts are failing, my Sept 11 (12MY) had its struts replaced by the dealer (at a fair old cost) in 2014 so the original set only lasted 2 years! The cars now over 8 years old on that second set. 2012 5.0 SC AB
Tue Jan 07 2020 10:44pm |
Silverstone Member Since: 04 Sep 2014 Location: Towcester Posts: 180 |
Had mine replaced at dealer on my MY2013 L320 last month. Even with staff discounts cost £365. Both should be done at the same time and takes technicians about 20 mins to recalibrate (apparently). There is no replacement for displacement - W O Bentley
Wed Jan 08 2020 12:30am |
Call me cynical but, I think the "recalibrate" is the expensive name for holdng the tailgate in the required position and press button until car "beeps".
Wed Jan 08 2020 1:10am |
Probably a screw thread made of cheese. 2012 5.0 SC AB
Wed Jan 08 2020 9:04am |
The struts were the problem!!
Thu Feb 20 2020 11:35pm |
If the new struts were a good price might be worth adding a link to them as may be of use to other members.
Thu Feb 20 2020 11:42pm |
Probably not the cheapest struts out there but the link is -
Fri Feb 21 2020 12:25am |
Seems like a fair price for a pair of the struts, probably be that for just one at L/R.
Fri Feb 21 2020 12:40am |
Stavroskon Member Since: 02 Dec 2021 Location: Athens Posts: 7 |
In my rrs 2013 after struts replacing with aftermarkets eBay … the tailgate open and close without pressing button for seconds time… any suggestions??? |
Sun Dec 05 2021 9:59am |
