![]() | Home > General > LED Wing Mirrors Retro fit |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5086 ![]() ![]() ![]() |
It's a long time ago I did mine but I'm sure it is the yellow wire on one side and green on the other but can't remember which is o/s and which is n/s, do have a spare pair of mirrors here so could have a look if you get stuck.
McFarTech Member Since: 13 Sep 2019 Location: Kent Posts: 126 ![]() ![]() ![]() |
with regards to cable.
It’s Pin 12 you need, that should be a vacant slot in your connector. On a MY14 Disco this was a Green and White wire of 0.5mm diameter. It’s earthed through the common mirror ground pin 6. So all you need to do is run a wire from the pos wire on your existing door indicator.
Yeah, this is what I did to mine, as Chris says got a couple of these A/B badges of fleabay and bonded them to the original repeater lamp plastic backing leaving original bulbholders in place, they then cliped in the hole same as original lamps did, did seal around edges though with silicone selant just to make sure they were watertight, being the 5.0L didn't want to use the SDV6 badges. Will have to have a look at the Disco 4 down here as a lot of them have the 5.0 engine in them I believe.
Thanks guys.
Personally thought it defeated the object of fitting mirrors with led indicators in them slightly if left in place.
Ok great. So it’s not something I need to do then.
I am going to need to try and pick up a pin connector so that I can put it in to connection 12. Any ideas on a product name , type , size of the pin.
Are you sure that's the end you want and not this one?
Thanks mate. Not sure why I didn’t think of buying the complete door harness. Even cheaper and can always salvage for parts in the future if needs be.
And let there be light!
