Home > General > LED Wing Mirrors Retro fit
It's a long time ago I did mine but I'm sure it is the yellow wire on one side and green on the other but can't remember which is o/s and which is n/s, do have a spare pair of mirrors here so could have a look if you get stuck.
Post #593133 Fri Jan 10 2020 10:00pm
McFarTech
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Orkney Grey
Thanks mate. ===========================================
2013 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Orkney Grey with cream and black leather.
Post #593134 Fri Jan 10 2020 10:01pm
McFarTech
with regards to cable.
12v 6amps or lower? ===========================================
Post #593136 Fri Jan 10 2020 10:40pm
Brit Plumber
It’s Pin 12 you need, that should be a vacant slot in your connector. On a MY14 Disco this was a Green and White wire of 0.5mm diameter. It’s earthed through the common mirror ground pin 6. So all you need to do is run a wire from the pos wire on your existing door indicator.
When LR fitted these mirrors to the Disco 4 they put a SDV6 or SC6 type badge in the old indicator hole. I did as Col recommended to me and fitted the boot badges over my holes. I think Col may have left his indicator based fitted but cut the lenses off before putting the badges on. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #593180 Sat Jan 11 2020 8:21pm
Yeah, this is what I did to mine, as Chris says got a couple of these A/B badges of fleabay and bonded them to the original repeater lamp plastic backing leaving original bulbholders in place, they then cliped in the hole same as original lamps did, did seal around edges though with silicone selant just to make sure they were watertight, being the 5.0L didn't want to use the SDV6 badges. Will have to have a look at the Disco 4 down here as a lot of them have the 5.0 engine in them I believe.
Post #593186 Sat Jan 11 2020 10:07pm
McFarTech
Thanks guys.
Sorry for a dim question. But why have you put a badge over your side repeater? ===========================================
Post #593187 Sat Jan 11 2020 10:13pm
Personally thought it defeated the object of fitting mirrors with led indicators in them slightly if left in place.
Post #593188 Sat Jan 11 2020 10:17pm
McFarTech
Ok great. So it’s not something I need to do then.
Was getting a bit worried then. 😂 ===========================================
Post #593191 Sat Jan 11 2020 10:33pm
McFarTech
I am going to need to try and pick up a pin connector so that I can put it in to connection 12. Any ideas on a product name , type , size of the pin.
Normally I would buy a broken park and take it from there but that’s not going to be an option with how expensive RR parts are.
Would this be correct? Obviously not the green connector. Throw that away. But the pins?
https://rover.ebay.com/rover/0/0/0?mpre=ht...1748526193
Craig ===========================================
Post #593227 Sun Jan 12 2020 9:23pm
Are you sure that's the end you want and not this one?
Unfortunate so far away as have a few of these here which have both ends, I think they came out of a door wiring harness I got of fleabay if I remember correctly something like this.
https://www.ebay.co.uk/itm/Land-Rover-Disc...SwWwBddiEL
Post #593228 Sun Jan 12 2020 10:01pm
McFarTech
Thanks mate. Not sure why I didn’t think of buying the complete door harness. Even cheaper and can always salvage for parts in the future if needs be.
Cheers for the little mental prompt there. ===========================================
Post #593230 Sun Jan 12 2020 10:53pm
McFarTech
And let there be light!
Thanks all for the help In getting this sorted. It was actually very straight forward. Pulling the door cards off and getting at the wiring was far easier than on my MK2 TT that I had.
Post #593423 Fri Jan 17 2020 4:18pm
Post #593451 Fri Jan 17 2020 10:18pm
