Home > General > LED Wing Mirrors Retro fit |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4833 |
Late Disco 4
Sat Oct 26 2019 9:04pm |
McFarTech Member Since: 13 Sep 2019 Location: Kent Posts: 126 |
Thats exactly what I am looking for.
Sat Oct 26 2019 9:05pm |
2014 on, could use RRS2 mirrors but still need Disco mountings that bolt to door. When I did mine I bought brand new mirrors probably have part numbers somewhere, but as usual with L/R rip-off prices the mirrors don't come complete.
Sat Oct 26 2019 9:14pm |
Thanks mate. If you do have part numbers that will be grand. ===========================================
Sat Oct 26 2019 9:17pm |
I will dig them out later but will be around a £1000.00 for new parts, or it did four years ago when I did mine.
Sat Oct 26 2019 9:23pm |
Good find thanks mate. would just need to get them colour coded to my car colour.
Sat Oct 26 2019 9:28pm |
Shouldn't be to far away in Maidstone at least same county. If you have surround cameras that is a bit of a problem as RRS1's are totally different to the RRS2. Might have to activate the approach lights in the CCF files if you don't have those either. Also with Disco mirror approach lights the icon will different to the Sport.
Sat Oct 26 2019 9:34pm |
andyslandy Member Since: 20 Oct 2019 Location: Chesterfield Posts: 142 |
Col beat me to that one, McFarTech said parts numbers would be grand and i was going to say that's probably what it would cost. |
Fri Nov 01 2019 11:01am |
I got mine second hand off eBay. I say second hand but by the time I’d built the spec I wanted, there was only 1 original part left and the rest was new from eBay.
Sat Nov 02 2019 1:44pm |
Bit the bullet and ordered the set off Ebay. should be with me this week. ===========================================
Fri Jan 03 2020 10:47pm |
Guys.
Fri Jan 10 2020 3:15pm |
Here is the connection. This is from the original mirrors but the Disco 4 block is exactly the same. Ive been hunting around , they only thing I can see close to this issue is using Disco 4 mirrors on a Disc 3 and someone had to wire the green which they identified as the led positive to the side indicator positive. I have no issues with doing that if its the correct thing. I had assumed this was all plug and play.
Fri Jan 10 2020 6:22pm |
They don't need coding, but you do need to run a wire from the side repeater to the mirror led indicator feed, as I had some spare bits of harness around just found a wire with terminal on it which fitted in to the original plug on the car and connected it to the side repeater wiring also left original repeater bulb holder in place.
Fri Jan 10 2020 9:16pm |
Thanks mate.
Fri Jan 10 2020 9:57pm |
