Home > General (L494) > 1 month in and this
Page 2 of 3 <123>
JamieLC
Thanks for the reply, by doing a reset do you mean just remove the code? Cheers
Post #585455 Sat Aug 17 2019 9:01am
IRBails
Australia
Clear the code. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #585456 Sat Aug 17 2019 9:27am
DrRob
Get a GAP IID Bluetooth from Dan at Duckworths. Best tool for home users Thumbs Up
https://www.fullfatrr.com/forum/topic47809.html
Not cheap but they are the Censored nuts Thumbs Up * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #585457 Sat Aug 17 2019 9:31am
IRBails
Australia
I HAVE A CHEAPER ALTERNATIVE. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #585459 Sat Aug 17 2019 10:15am
JamieLC
So I wiped the fault code and it’s stayed off for a few days but this morning returned! Any body else have any ideas or is it time to go to Landrover?
Post #585615 Tue Aug 20 2019 2:25pm
IRBails
Australia
Time to see the dealer for specific diagnosis . M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #585645 Tue Aug 20 2019 11:42pm
PetesRRS
Australia 2013 Range Rover Sport SDV6 HSE Fuji White
I had this happen to me. Turned out to be a pressure sensor in the egr system. Replaced sensor and all good
Post #585648 Wed Aug 21 2019 5:58am
JamieLC
PetesRRS did you get it sorted at Dealers? If so was it just a one day thing? The car seems to be driving fine, no issues.
Post #585666 Wed Aug 21 2019 11:33am
PetesRRS
Yes dealer fixed. There was an error code which pointed at sensor failure. Cannot recall error code now. Sensor had to be ordered delivered next day. There was no indication anything was wrong except for engine light on. Car appeared to be running fine
Post #585906 Tue Aug 27 2019 7:52am
JamieLC
Yep mine is exactly the same. Running perfectly, well at least I think it is only had the car 3 months. 🙂
I keep getting the same code (P049B) after I’ve cleared. At Stratstone on Friday any way
Post #585926 Tue Aug 27 2019 3:42pm
airwolf222helicopters
Just to let you know
LR ASSIST are the AA. Was told this when I called them out once by the LR assist guy that turned up he said we just get trained for land rovers but we are AA
So your best bet is to join AA They have all the diagnositic software Thumbs Up
Post #585939 Tue Aug 27 2019 10:11pm
JamieLC
Thanks for the reply and the advice. Just out of curiosity which cover do you have, I was quoted 45 quid for the year does that sound about right? That’s just the basic package I believe
Post #585948 Wed Aug 28 2019 10:24am
DangerMouseUK
United Kingdom 2013 Range Rover Sport Supercharged Santorini Black
The JLR breakdown fleet for customers is also run by The AA! Non JLR Vehicle
Post #586046 Thu Aug 29 2019 9:32pm
JamieLC
Thanks that’s handy to know. The car is in the dealers today so should know more and I think I will be taking out a policy with AA Thumbs Up
Post #586066 Fri Aug 30 2019 7:49am
JamieLC
So had the car in the dealers today and as you said PeteRRS it was a sensor.
They also carried out the free vehicle health check. Results were -
Front anti roll bars bushes worn - They recommend getting sorted but nothing major. (Not covered by warranty as wear and tare)
Auxillary belt pulleys noise - Would need further investigation. (Any input by you guys is welcomed)
Transfercase leaking oil - this made me panic a bit when I seen the price - £686 (They said as it’s only minor and an advisory I should go back in a few weeks for a check up - covered by warranty any way)
So any way it was agreed that I will take the car back in a couple of weeks and get the transfer case leak checked, further investigate the auxiliary noise and change the sensor. They removed the EML light but they said it will continue to flicker on and off until the sensor is changed.
Thanks for every ones response and advice Thumbs Up
Post #586117 Fri Aug 30 2019 10:30pm
Page 2 of 3 <123>
