Home > General > remap on tdv8
wilpert
United Kingdom 2007 Range Rover Sport TDV8 HSE Santorini Black
remap on tdv8
Just had my TDV8 daily drive through an MOT, passed without problems, except front brake pads so all good.
Except the garage said the egr valves might need to be replaced as I am getting engine light come up and this seems to be the problem.
He said that if I get a remap carried out they can delete the egr from the ecu, so it will resolve the problem.
Anybody know about this or any other reason why a rempa might be a positive on this car.
FWIW It is my daily driver, (most of the time) and covered 148k miles, so its no garage queen.
Post #583880 Fri Jul 12 2019 2:18pm
Sharpy1980
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
I decided to remap mine out rather than replace the egrs although I decided to blank them also as I have heard of the egrs breaking up and going into the engine it's rare but I decided to go the whole hog, I was also happy with the power before hand but as I was doing it thought I’d have the mild tune but what I noticed straight away was how much better the throttle response was when pulling out on roundabouts etc it is so much better on light throttle 👍 Clickadeeclick
Post #584097 Wed Jul 17 2019 10:15am
DrRob
Bell Auto Services and their network Thumbs Up * Current: 2024 D350 Defender 90 on coils!
* Current: 1974 Lightweight 2.25L petrol. Old skool
* GONE: 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8
I use www.glenrands.co.uk Great independent specialist!
Post #584098 Wed Jul 17 2019 11:09am
SvenGB
How much did you guys pay for the remap? Did you much of an increase in mpg?
Post #584146 Fri Jul 19 2019 7:09am
Japseroony
England 2008 Range Rover Sport TDV8 HSE Stornoway Grey
In order to get more power (via the remap) you need to put more in so in general a remap will slightly reduce MPG - having said that, once you get used to it you may notice a slight gain as you have more power when you need it and you don't have to push your right foot down so far, so a slight gain may be possible Thumbs Up
BAS is the place to go as they are pioneers in tuning Wink "UNDERSTEER" ----is when you hit the fence with the front of the car.
"OVERSTEER" ------is when you hit the fence with the rear of the car.
"HORSEPOWER" ----is how fast you hit the fence.
"TORQUE" -----------is how far you take the fence with you.
Post #584155 Fri Jul 19 2019 11:38am
SvenGB
I’ve never seen a remap advertised without a mpg increase before - is this mpg loss a nuance of the RRS?
Post #584241 Sun Jul 21 2019 9:31am
Japseroony
SvenGB, really surprised at that as most remaps offer an increase in power not MPG Thumbs Up
Any credible tuner will tell you if you want more power then in order to get that you have to fuel more so in general if you use the power you will reduce the MPG but as previously said, once you get used to the power you might notice a slight increase.
If a tuner says you can have more power and a higher MPG they are not being very honest and in order to give you more MPG they would have to de-tune your car.
This is not a RRS issue or a LR one but tuning in general and would apply to all vehicles Thumbs Up "UNDERSTEER" ----is when you hit the fence with the front of the car.
Post #584244 Sun Jul 21 2019 10:48am
ShooterNeil
England 2007 Range Rover Sport TDV8 HSE Java Black
I had mine remover and remapped by Ian Bodsworth think all in was around 600£ 61 AB 5.0 supercharged rocket
07 HSE TDV8 with lots of toys EGR removed BAS remap
56 HSE WAS FULL OF PROBLEMS
Post #584276 Sun Jul 21 2019 8:30pm
