![]() | Home > General > Dash Cam - which one? |
Hi,ive got the Thinkware 770 with rear facing camera & find it very easy to use & can either be hard wired or cigarette light socket.
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
This is mine http://www.dx.com/p/viofo-a119s-v2-capacit...vlSVy0vyUk
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 783 ![]() ![]() ![]() |
Thinkware 770 for me as well, easy to install with hard wire kit and so far very reliable. I used two piggy back fuses as it needs a permanent live for parked recording. They are not cheap but get good reviews. |
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 341 ![]() ![]() ![]() |
Thanks for that Steve!! Did you install it yourself? I'm just wondering if it needs a call in at my local garage or perhaps DIY. Does it come with all the required wires etc. Andrew Andrew Kennedy |
I took mine to a local auto elec. Charged me £30...not worth the hassle |
Having a look on line, the THINKWARE F770 DASH CAM for front and rear windows looks a good system?!? Anyone out there any experience with this model and make?? Andrew Kennedy |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 ![]() ![]() |
If you're going to install it yourself like I did, check the input voltage of the camera as most of them I believe are 5v and you will fry it if you hard wire it into the 12v electrics.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5091 ![]() ![]() ![]() |
Have had the F770 Front and Rear cameras fitted for 2/3 years now and never had any problems at all, has some good features included i.e. speed camera location etc, 12volt so easy to wire straight in. Will also accept a 128gb card (only certain one's though) although spec. says 64gb max. Not the cheapest on the market though, but personally think its one of the best and worth it. |
Richythepom Member Since: 01 Aug 2015 Location: Essex Posts: 68 ![]() ![]() ![]() |
Hi there, I recently fitted a Cobra IP dashcam to my '08 RRS - full install guide at the of this thread:
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 ![]() ![]() |
I recently did the Mini 0906 dual dashcam ( currently installed in both our RRS and X1 )
Auto-Express this week has a big test of dash cams that you might like to read before deciding which one to buy.
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 ![]() ![]() |
Autoexpress’s photo of the Blackvue bracket upside down is triggering an OCD attack here. But clearly the best money-no-object camera. Right? My only concern is the bandwidth (and therefore time) it would take to upload a parking incident. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Mine died after 12 months. Steve. |
Picked up a cam that clips onto rear view mirror and rear cam for 35 quid on ebay and another tenner for a hardwire kit. Full hd and audio. Hardest part of fitting was piggybacking the fuse as those fuses are tiny and the wee red fuse extractor tool is a pile of keech, skinny long nose pliers rule. |
