Home > General > Dash Cam - which one?
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
Any advice on which Dash Cam is considered best for installing into a 2006 Sport? I might try to do the installation myself so any guide as to installation procedure/instructions would be much appreciated!! Andrew Kennedy
Post #556375 Mon May 14 2018 7:26am
Tyrefitter
Hi,ive got the Thinkware 770 with rear facing camera & find it very easy to use & can either be hard wired or cigarette light socket.
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #556376 Mon May 14 2018 7:38am
Cymruambyth
Wales
This is mine http://www.dx.com/p/viofo-a119s-v2-capacit...vlSVy0vyUk
Does everything I need and with it being a wedge shape, sits nice and discreet behind the RVM Thumbs Up Steve.
Post #556388 Mon May 14 2018 9:10am
Oldandconfused
Thinkware 770 for me as well, easy to install with hard wire kit and so far very reliable. I used two piggy back fuses as it needs a permanent live for parked recording. They are not cheap but get good reviews.
Post #556392 Mon May 14 2018 10:09am
andrew kennedy
Thanks for that Steve!! Did you install it yourself? I'm just wondering if it needs a call in at my local garage or perhaps DIY. Does it come with all the required wires etc. Andrew Andrew Kennedy
Post #556393 Mon May 14 2018 10:11am
Cymruambyth
Wales
I took mine to a local auto elec. Charged me £30...not worth the hassle Thumbs Up I had to buy a hard wire kit off ebay for a tenner. Steve.
Post #556399 Mon May 14 2018 11:48am
andrew kennedy
Having a look on line, the THINKWARE F770 DASH CAM for front and rear windows looks a good system?!? Anyone out there any experience with this model and make?? Andrew Kennedy
Post #556419 Mon May 14 2018 2:03pm
Scrumpy
If you're going to install it yourself like I did, check the input voltage of the camera as most of them I believe are 5v and you will fry it if you hard wire it into the 12v electrics.
Easy to rectify though, you can buy a step down convertor (converts 12v to 5v) for about £10 on popular auction sites and they usually come with the correct lead for the camera too (ie micro or mini USB).
Good luck! 2016 RRS SVR Estoril Blue
Post #556423 Mon May 14 2018 2:36pm
Have had the F770 Front and Rear cameras fitted for 2/3 years now and never had any problems at all, has some good features included i.e. speed camera location etc, 12volt so easy to wire straight in. Will also accept a 128gb card (only certain one's though) although spec. says 64gb max. Not the cheapest on the market though, but personally think its one of the best and worth it. Thumbs Up
Post #556465 Mon May 14 2018 10:43pm
Richythepom
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Hi there, I recently fitted a Cobra IP dashcam to my '08 RRS - full install guide at the of this thread:
http://www.rrsport.co.uk/forum/topic50427-15.html
Hope this helps,
Rich[/url] 2008 RRS HSE Stornoway Grey
Post #556482 Tue May 15 2018 10:16am
mrluke
I recently did the Mini 0906 dual dashcam ( currently installed in both our RRS and X1 )
http://www.rrsport.co.uk/forum/topic50823.html
Good camera and uses a capacitor which is a a lot better, as all my dash cams i have used in previous cars have all had dead battery's eventually which will cause corruption on the last file save when the ignition turns off .
Post #556774 Fri May 18 2018 7:49am
Tim in Scotland
Auto-Express this week has a big test of dash cams that you might like to read before deciding which one to buy.
http://www.autoexpress.co.uk/accessories-t...ed-to-know 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #556776 Fri May 18 2018 8:05am
ilard
Autoexpress’s photo of the Blackvue bracket upside down is triggering an OCD attack here. But clearly the best money-no-object camera. Right? My only concern is the bandwidth (and therefore time) it would take to upload a parking incident. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #557180 Tue May 22 2018 7:33pm
Cymruambyth
Wales
Mine died after 12 months. Steve.
Post #557181 Tue May 22 2018 7:36pm
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
Picked up a cam that clips onto rear view mirror and rear cam for 35 quid on ebay and another tenner for a hardwire kit. Full hd and audio. Hardest part of fitting was piggybacking the fuse as those fuses are tiny and the wee red fuse extractor tool is a pile of keech, skinny long nose pliers rule.
Post #557203 Wed May 23 2018 7:19am
