![]() | Home > General (L494) > Anyone hardwired a dashcam in L494? |
Just a quick note to say I have hardwired my BlackVue. As a bonus, also made my rear sockets permanent live to enable CTEK trickle charging via the boot socket. I think both are working as expected.
rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879 ![]() ![]() |
I have a forward facing dash cam and I see there are also front and rear recorders, are these 2 separate units that need to be wired to a permanent live or is it one unit with 2 lenses mounted in the front ? MY16 AUTOBIOGRAPHY Indus silver with some toys
Dave777 Member Since: 15 Feb 2015 Location: Sussex Posts: 485 ![]() ![]() |
Thanks fkarim can't wait. Really want to fit one of these in mine. MY16 3.0 SDV6 Autobiography in Aleutian silver, stealth pack and toys. |
I have a a Blackvue DR500GW HD single camera system with Power Magic hardwiring kit. Due to Power Magic, the camera always stays on when the engine is running and also when turned off (Parking Mode) until battery voltage drops below the specified threshold (only 11.8V & 12V are important as the other 2 higher values are for 24V batteries) OR a set number of hours elapses (24, 48 or 72). Whichever happens first makes Power Magic shut down supply to the camera. I have used it in my last 2 Sports and now fitted the same unit to the new one (I should really upgrade to a 2 channel/camera system!).
Thanks fkarim good job. Just need the rear one now! MY16 3.0 SDV6 Autobiography in Aleutian silver, stealth pack and toys. |
Thanks for the write up Fkarim, very helpful |
My Blackview and Power Pro should be here some time today with a bit of luck. Where is the best place to position the rear camera with regards to wiring it in ? Any photos of its position or pointers would be helpful. I took the rear panel trim off earlier and there seems plenty of room to fit the Power Pro there as per the instructions from Fkarim so Im going to have a go at it when it turns up. Ive got the fire extinguisher handy though |
Violetpiano Member Since: 03 Jun 2014 Location: London Posts: 561 ![]() ![]() |
RRSMan,
RRSman Member Since: 10 Feb 2015 Location: London Posts: 1439 ![]() ![]() |
Hi Jas,
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 554 ![]() |
A good question and one I wish I had asked previous to my install.... Firstly do not fit the rear camera centrally at the top of the screen. The reason for that is when it rains that area never gets cleaned by the rear wiper and therefore you'll see absolutely nothing.. Fit it slightly to one side at the top of the swept area. Secondly if you're trying to run the camera lead through the rubber grommet at the the top off tailgate it's an absolute ![]() The other issue is the tailgate is a bonded panel and there was nowhere I could get the other end of the camera lead to exit from the upper tailgate without drilling an additional hole.... I got round it in the end by cutting a notch in the boot lid end of the grommet and exiting the wire there.....not the neatest but it works.... The easy alternative is not to run it through the rubber grommets but run the wire straight from the rear headlining upto the rear window but you would have to leave a surplus loop for when the tailgate opens! Good luck! |
I've fitted loads of these devices to Rrs/d3/d4, but not yet to the L494.
Oops, just seen fkarims write up |
Thanks RRSman, I think I would prefer an authorised dealer / installer to do mine to. If you come across one please do let us know. Cheers Jas Current RRS: MY18 SVR Previous RRS: MY15 RRS 5.0L Autobiography |
