| RRSPORT.CO.UK | ||
|  | Home > Technical > Black Smoke! Getting boring |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | Chirping sound sounds like a leaking turbo gasket, or snapped manifold stud... | ||
|  Sun Jul 05 2015 9:48am |
| Olly-ibiza Member Since: 23 Aug 2014 Location: Chester/Ibiza Posts: 189  | Nah its deffo boost, iv had a snapped exhaust stud and its a different sound. I replaced them all with astra vxr studs and deep nuts. | ||
|  Sun Jul 05 2015 10:23am |
| TDV8_AutoB Member Since: 03 Jul 2015 Location: Berkshire Posts: 35      | just written this a second ago........but here goes again.
|  Sun Jul 05 2015 6:12pm |
| Olly-ibiza Member Since: 23 Aug 2014 Location: Chester/Ibiza Posts: 189  | Its non of the 4 ic pipes had them all off and checked them properly | ||
|  Sun Jul 05 2015 7:15pm |
| gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494    | manifold   | ||
|  Sun Jul 05 2015 7:50pm |
| Olly-ibiza Member Since: 23 Aug 2014 Location: Chester/Ibiza Posts: 189  | Inlet manifold? | ||
|  Sun Jul 05 2015 7:58pm |
| gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494    | exhaust,my tdv8 did it for ages tried everything,but every time i drove with window open i could hear the chirping noise ,i hope its something easier on yours but thats what mine ended up as   | ||
|  Sun Jul 05 2015 8:21pm |
| Olly-ibiza Member Since: 23 Aug 2014 Location: Chester/Ibiza Posts: 189  | Like iv said a bit further up, I replaced all the exhaust studs and nuts with better quality ones from an astra vxr.
|  Sun Jul 05 2015 8:25pm |
| gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494    | the exhaust manifold on mine had loads of pitting in it and was blowing like a fart every time boost came in ,like i said mate i hope yours aint that ..just telling you what mine turned out to be  | ||
|  Sun Jul 05 2015 8:31pm |
| Olly-ibiza Member Since: 23 Aug 2014 Location: Chester/Ibiza Posts: 189  | Has anyone ever had to replace the metal boost pipes coming from the turbo? Also does anyone have any pictures of the leak in their intercooler so iv got an idea where their weak point is | ||
|  Mon Jul 06 2015 8:25am |
| Tomrogers Member Since: 12 Jan 2015 Location: Mk Posts: 18  | When you check the pipes it's worth actually removing them and checking as I recently checked min on the car and all looked good it was only when I took it off I found a split about 2 inches long on the under side of it | ||
|  Mon Jul 06 2015 9:03am |
| TDV8_AutoB Member Since: 03 Jul 2015 Location: Berkshire Posts: 35      | Look for visible signs of soot around the pipes - if it's been blowing for a while there will be some evidence and that'll give you a clue where to look. | ||
|  Mon Jul 06 2015 9:22am |
| Olly-ibiza Member Since: 23 Aug 2014 Location: Chester/Ibiza Posts: 189  | Iv had all the ic pipes off and scrubbed all the   | ||
|  Mon Jul 06 2015 9:47am |
| Olly-ibiza Member Since: 23 Aug 2014 Location: Chester/Ibiza Posts: 189  | Just an update to my remaining problem
|  Mon Jul 13 2015 10:31am |
| Posting Rules
 off them and they are all in good nick! Cant see any turbo sweat anywhere around the ic as most if it is covered up. Just want to see an ic that someone has replaced to see where they go. If its in the core or at the edge ect and if anyone in here has any problems with the pipework nearer the turbos
