![]() | Home > Technical > Black Smoke! Getting boring |
Chirping sound sounds like a leaking turbo gasket, or snapped manifold stud... |
| Olly-ibiza Member Since: 23 Aug 2014 Location: Chester/Ibiza Posts: 189 |
Nah its deffo boost, iv had a snapped exhaust stud and its a different sound. I replaced them all with astra vxr studs and deep nuts. |
| TDV8_AutoB Member Since: 03 Jul 2015 Location: Berkshire Posts: 35
just written this a second ago........but here goes again.
Its non of the 4 ic pipes had them all off and checked them properly |
| gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494
manifold |
Inlet manifold? |
exhaust,my tdv8 did it for ages tried everything,but every time i drove with window open i could hear the chirping noise ,i hope its something easier on yours but thats what mine ended up as |
Like iv said a bit further up, I replaced all the exhaust studs and nuts with better quality ones from an astra vxr.
the exhaust manifold on mine had loads of pitting in it and was blowing like a fart every time boost came in ,like i said mate i hope yours aint that ..just telling you what mine turned out to be |
Has anyone ever had to replace the metal boost pipes coming from the turbo? Also does anyone have any pictures of the leak in their intercooler so iv got an idea where their weak point is |
| Tomrogers Member Since: 12 Jan 2015 Location: Mk Posts: 18 |
When you check the pipes it's worth actually removing them and checking as I recently checked min on the car and all looked good it was only when I took it off I found a split about 2 inches long on the under side of it |
Look for visible signs of soot around the pipes - if it's been blowing for a while there will be some evidence and that'll give you a clue where to look. |
Iv had all the ic pipes off and scrubbed all the |
Just an update to my remaining problem
| All times are GMT |
