Home > Technical > Black Smoke! Getting boring
Olly-ibiza
Tdv8 put your foot down black Smoke, when driving little chuffs of smoke and reduced performance.
Getting a little chirping noise when it comes in boost at about 2000rpm
sounds like a little boost leak.
Checked all 4 ic boost pipes, just bought new egr valves which im going to fit on tuesday, iv visually inspected as much of the ic as I can without removing it. Is there a common place they fail? Is it visable?
Any body had any other odd places for boost leaks??
Post #466575 Sun Jul 05 2015 9:52am
Disco_Mikey
Chirping sound sounds like a leaking turbo gasket, or snapped manifold stud...
Post #466578 Sun Jul 05 2015 10:48am
Olly-ibiza
Nah its deffo boost, iv had a snapped exhaust stud and its a different sound. I replaced them all with astra vxr studs and deep nuts.
Post #466580 Sun Jul 05 2015 11:23am
TDV8_AutoB
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Alaska White
just written this a second ago........but here goes again.
Check the right turbo pipe that (as you face the engine on the right) - it comes up from under and joins near the top. It's a jubilee clip. Mine had exactly the same noise, I thought it was normal (I've only had the car a week), but power never seemed right for a V8 - anyway, the noise wasn't normal and it was coming from the leak on the inlet boost side.
You'll probably have a manifold boost pressure error showing too.
Also check which side the black comes from - if it's drivers side (as mine was) then check the opposite side of the engine. The ECU compensates for the air leak and chucks more fuel in the opposite bank, ultimately blowing unburnt diesel out the back in the form of good old black smoke !
David
Post #466615 Sun Jul 05 2015 7:12pm
Olly-ibiza
Its non of the 4 ic pipes had them all off and checked them properly
Post #466625 Sun Jul 05 2015 8:15pm
gazzc
2005 Range Rover Sport TDV6 HSE Siberian Silver
manifold Whistle silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Rimini red rrs 2.7 tdv6 steps. Full c code. Recon engine!!loved but!gone ,thank god !!
Gone rr sport supercharged. Loved but 11mpg !!!
current,triumph stag mk2...current bmw 325 sport convertible
Post #466630 Sun Jul 05 2015 8:50pm
Olly-ibiza
Inlet manifold?
Post #466631 Sun Jul 05 2015 8:58pm
gazzc
exhaust,my tdv8 did it for ages tried everything,but every time i drove with window open i could hear the chirping noise ,i hope its something easier on yours but thats what mine ended up as Thumbs Up silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #466636 Sun Jul 05 2015 9:21pm
Olly-ibiza
Like iv said a bit further up, I replaced all the exhaust studs and nuts with better quality ones from an astra vxr.
The problem I have here is boost leaking not exhaust
Post #466638 Sun Jul 05 2015 9:25pm
gazzc
the exhaust manifold on mine had loads of pitting in it and was blowing like a fart every time boost came in ,like i said mate i hope yours aint that ..just telling you what mine turned out to be Neutral silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #466641 Sun Jul 05 2015 9:31pm
Olly-ibiza
Has anyone ever had to replace the metal boost pipes coming from the turbo? Also does anyone have any pictures of the leak in their intercooler so iv got an idea where their weak point is
Post #466673 Mon Jul 06 2015 9:25am
Tomrogers
When you check the pipes it's worth actually removing them and checking as I recently checked min on the car and all looked good it was only when I took it off I found a split about 2 inches long on the under side of it
Post #466678 Mon Jul 06 2015 10:03am
TDV8_AutoB
Look for visible signs of soot around the pipes - if it's been blowing for a while there will be some evidence and that'll give you a clue where to look.
Post #466687 Mon Jul 06 2015 10:22am
Olly-ibiza
Iv had all the ic pipes off and scrubbed all the Censored off them and they are all in good nick! Cant see any turbo sweat anywhere around the ic as most if it is covered up. Just want to see an ic that someone has replaced to see where they go. If its in the core or at the edge ect and if anyone in here has any problems with the pipework nearer the turbos
Post #466690 Mon Jul 06 2015 10:47am
Olly-ibiza
Just an update to my remaining problem
Replaced Egr valves, checked all 4 short rubber hoses on manifold, checked manifold for cracks. When manifold was off the pipe feeding the offside bank was all wet and oily the pipe feeding the nearside was all dry and charred like the inside of and exhaust.??
Built it back up no difference at. Also its been a bit lumpy in the mornings when pulling off... Any more ideas before I drive it in to the sea?? spiteful Range Rover Sport tdv8
Post #467383 Mon Jul 13 2015 11:31am
