| RRSPORT.CO.UK | ||
|  | Home > Maintenance & Modifications > Couple of little mods from a new owner |
| Mister B Member Since: 25 Apr 2014 Location: South West Posts: 179      | very nice and a lot planned too.  I do like them in white (saw a pink one yesterday  )
|  Fri Apr 03 2015 8:47am |
| Si-W85 Member Since: 22 Mar 2015 Location: Huddersfield Posts: 109  | Thanks   | ||
|  Fri Apr 03 2015 9:02am |
| B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420      | Your car looks fab mate   | ||
|  Fri Apr 03 2015 10:14am |
| Si-W85 Member Since: 22 Mar 2015 Location: Huddersfield Posts: 109  | Thank you   | ||||
|  Fri Apr 03 2015 10:22am |
| B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420      | Yep thats the audi i saw, looks gr8  | ||
|  Fri Apr 03 2015 10:51am |
| Si-W85 Member Since: 22 Mar 2015 Location: Huddersfield Posts: 109  | That's correct just chopped off and welded in place 2 straight pipes unfortunately I don't have any before and after pics, I will be going for a custom cat back with just the 2 rear silencers, I will be doing away with the centre silencer and the cross over box, I'm pretty sure that will be the sound I am going for. | ||
|  Fri Apr 03 2015 11:49am |
| zaphod Member Since: 16 Jan 2015 Location: UK Posts: 290      | LED side lights look so much better   | ||
|  Fri Apr 03 2015 12:03pm |
| B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420      | will u be fitting the cross over box in replace with the straight pipes fitted?
|  Fri Apr 03 2015 12:36pm |
| Si-W85 Member Since: 22 Mar 2015 Location: Huddersfield Posts: 109  | Just noticed my fog lamps are a bit yellow so that's something else I will be upgrading. I will be using a custom exhaust place to make me one up, not too sure about the crossover box and how much it is needed but if I can do away with it I will do as that with it being ported will hold back a lot of the noise  | ||
|  Fri Apr 03 2015 1:32pm |
| JayJay Member Since: 27 Feb 2014 Location: wolverhampton Posts: 50    | Very nice mate...   | ||
|  Fri Apr 03 2015 4:58pm |
| gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 961      | nice clean engine bay   | ||
|  Fri Apr 03 2015 6:49pm |
| Si-W85 Member Since: 22 Mar 2015 Location: Huddersfield Posts: 109  | Hi Gogsy, thanks it's actually quite easy to do, I first applied some Autoglymm engine/machine wash and agitated with a soft brush for a few minutes I then started the engine and pressure washed off staying clear of the battery cover as that is where the ecu is, I left the engine running for 10 minutes and turned off and left over night to dry thoroughly. The next day when it was dry I got out the Meguires dash & trim restorer and a yellow Polish pad and did the scuttle panel and all the black bits in the engine even the hoses etc etc I am happy with the finish and it has made the engine bay look so much better. Here are the things I used minus the brush which I got in the halfords 3 for 2 offer.   | ||
|  Sat Apr 04 2015 7:52am |
| Si-W85 Member Since: 22 Mar 2015 Location: Huddersfield Posts: 109  | Today's little mod  | ||
|  Sat Apr 04 2015 6:59pm |
| zaphod Member Since: 16 Jan 2015 Location: UK Posts: 290      | Nice - funnily enough I've just done the exact same mod (look in my gallery) a few hours ago to my Sport. I much prefer the look of white indicator lenses than orange, they're more modern and clean looking   | ||
|  Sat Apr 04 2015 9:26pm |
| Posting Rules
 it is satin pearl colour sounds worse than it looks when I found out the colour under the wrap Rimini red I intended on pulling the wrap off as that is my favourite colour RRS but when I got there to see the car I changed my mind and fell in love with the colour and will be keeping it like that for some time it looks so much better in person and get a lot of great comments on it so far. I thought when I spoke to the bloke on the phone and he said it was satin pearl I thought it may look a bit hairdresser but it really doesn't.
